Cam Timing Specs for 2.2E
Doing the cam timing tonight and I want to double check the spec on the cam timing for a 2.2E. I belive it is supposed to be 3.0-3.3mm at .10mm lash is that correct?? Thanks in advance
Dean |
Yep. Straight from the spec book!
Thanks Early S!!!
Dean |
| All times are GMT -8. The time now is 06:23 AM. |
