Ride Height - How low is too low?
So for the folks running lower ride heights (Lower than euro) what tricks are you using to keep from rubbing?
My example - 84 Carrera 22/29 t-bars, Sport Bilsteins, max camber front and rear, running 17 inch Fikse 255 rear and 225 front. I am at about 24.5 in the rear and 24.25 in the front (fender to ground, I know not super accurate but close enough for comparo purposes. As it stands now I need an adjsutable bump steer kit (have rack spacers) but tie rod angles are still off. What are other folks running? http://forums.pelicanparts.com/uploa...1312918083.jpg |
Well, legally when something hangs lower than tire height. Mechanically when shocks bottom out or when the steering is compromised.
Around 23 inches or less at wheel arch to ground is where it gets iffy. |
How low is to low? When a CHP pulls you over, pulls out his billy club with a notch on it and checks to see if the center of the head light is below or above notch.
I think mine is stock. I know I've never change the ride height and the PO did not either. 25" front and 24.5" rear. Seems just right to me. I'm also running stock tire/wheel sizes. Only the sway bars are a little larger but that wouldn't contribute to a height change.
That's about euro ride height. Should be OK unless you do something stoopid like run 24s with rubber band tires....
When your front control arms are level or the inner most point is lower than the ball joint, that is to low.
You want to keep the front a-arm at an angle so that the inner bushings are higher than the ball joint. RIch |
Parker,
I have pretty much the same setup as you on my 89 including the steering rack spacers and everything is fine,even on the track... My hand does not fit between the top of the rear tire and the fender in the rear and in the front my knuckles just clear it. Your car looks perfect the way it is ! Cheers ! Phil |
"So for the folks running lower ride heights (Lower than euro) what tricks are you using to keep from rubbing?" ...16" Fuchs.... Mine is a little lower than real 'Euro'; not much though. I think your front needs to go up maybe 1/2". Just IMHO. But then I don't like 17s, but just my opinion of course. Your car looks pretty sharp (otherwise)! ;) :)
I'm at about 24.75 FR and 24.25 RR. I have no rubbing on 225/255 on 17s, though my front fenders are rolled. To combat bump steer, my front spindles are raised 3/4 of an inch with Elephant's bump steer kit. I have no bump steer at all now. The pic below is about a quarter inch higher than these measurements. It wouldn't hurt my feelings to get back up to that height.
http://forums.pelicanparts.com/uploa...1312944193.jpg |
its never too low, slammed with everything else stock, no rubbing at all. used to rub with 225's at the front now with 205's all good.
http://img190.imageshack.us/img190/5281/lown.jpg |
Now that looks low ... :)
Nice picture ! Cheers ! Phil |
Torsions are 22/28, but sways are stock.
Thank you very much.
Just my .02.. JR |
syzygy, not to be a pain in the butt, but I have another question. You say in your original post that in the picture posted above that your car sat a quarter of an inch higher, front and rear.
Was the suspension at that time as you have it now (raised spindles and 22/28 torsions) or was it stock? I ask because I'd love to get a set of Zuchs for my car and it currently sets at the ride height in your pic. Thank you. |
I think I need the bolt on bump steer kit. |
Early this summer, I had the suspension refurbished with some upgrades. Larger torsion bars were installed as well as new struts with raised spindles. In the process of corner balancing and alignment, it was lowered about 1/4 inch; it used to be 25/24.5 inches. That wasn't my intent and I suppose I wasn't clear enough in my desires. Regardless of the height, the bump steer issue has all but disappeared. |
I'm at 24 and 24.5 - really about as low as I want to go.
Bump steer kit - http://forums.pelicanparts.com/uploa...1289081078.jpg with my track wheels http://forums.pelicanparts.com/uploa...1294087541.jpg at speed http://forums.pelicanparts.com/uploa...1305208946.jpg http://forums.pelicanparts.com/uploa...1305209144.jpg |
Once it is as low as it can go. Mounts 15 inch rims with low profile tires for the track and now you are talking.
Chris 73 911 E |
Jeremy reagarding the bump steer kit - you talking rack spacers or tie rod kit or both? Like I said I am at 24.5 and 24.25 and my tie rods are reaching for the moon, with the rack spacer. |
Rack spacer on mine - that's all - even with sebring (known for lots o bumps) not bad at all
I just got the car back from the shop. It was not level so I had it adjusted and the alignment re-done. I went about as low as you can go with no rubbing. The rear was about 1/2" lower and we had to take it back up. It's currently set at 24-7/8"rear and 25-1/8"front. Running 16x6s front and 16x7s in the rear. Suspension is stock with Bilstein shocks. I have been wondering if I need the bump steer kit, but honestly haven't spent any time on it as I've been working on so many other things on the car.
Here's a pic: http://forums.pelicanparts.com/uploa...1313169153.jpg |
At what point do drop spindle struts make sense?
I can't imagine being able to go lower than Jeremy with my car. Thoughts? |
Raised spindles for me was to correct suspension geometry and eliminate bump steer. I suppose if your steering is kinda wonky (bump steer or tie rods level or angled up) it might be time.
My 79 with 17 inch wheels sits at 26.5 front 25 rear.
Pretty much all ER track race with 23 / 31 Torsion bars and Tarret sways. 225/15 in front with 235/15 in rear on 7s and 8s. Fenders were rolled before paint.http://forums.pelicanparts.com/uploa...1313288247.jpg
However. If you do raise the spindles you will require a bump steer kit as the steering arm/knuckle gets raised as well. If you have objectionable bump steer, this part is a no brainer. |
Any idea how much?
Elephant shows these strut spindle heights: +19mm / 15 inch wheels +30mm / 16 inch wheels +40mm / 17 inch wheels Custom height available I'm trying to understand why wheel size matters if you go with the appropriate size tire to keep the tire diameter the same. |
If you raise the spindle the ball joint almost rubs on the inner wheel rim so the wheel size dictates how far you can raise them.
Here is standard height. If you raise the spindle the A-arm stays where it is but the wheel moves up.
http://farm6.static.flickr.com/5018/...62d4d4ee_z.jpg Front Suspension Geometry_ 012 by Max_911_fahrer, on Flickr |
You canīt get low enough.. :)
http://forums.pelicanparts.com/uploa...1314041767.jpg http://forums.pelicanparts.com/uploa...1314041968.jpg |
