Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
front oil cooler line removal
Has anyone tried or had any success removing these lines by carefully dremmelling the nuts on these small lines to the front oil cooler and hard oil lines?
"Charlie don't surf!"
Old 08-09-2011, 06:16 PM
Joe Bob's Avatar
Yes, but they will come off with a big ass crescent and vice grips.......maybe heat if really stubborn.
See me for graphics. www.nbdgraphics.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 08-09-2011, 06:26 PM
Weekend Mechanic
vulcan300's Avatar
The nuts came off the brass lines on my car without too much trouble but the nuts on the other end were fused to the threads on the aluminum cooler. I removed them with heat and a very long breaker bar but the aluminum threads were destroyed in the process. If I had to do it over again I would go with the dremel method. Good luck.
86 911 Carrera Targa
Old 08-09-2011, 06:50 PM
Northern Motorhead
wildcat077's Avatar
I removed mine over the Winter when i changed the oil cooler seal and the thermostat ...
Use a torch with the MAPP gas (yellow bottle) and don't be afraid to apply the heat and soak it with lots of PB Blaster !
Takes a little more time but it's a safe way to do it without taking out the threads ...
I think i used my spring plate eccentric bolt wrench and a crescent wrench which i grinded the opening to make it bigger on the fittings as they are different sizes !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-09-2011, 07:05 PM
success
Just to finish off this thread...What a SOB to remove these nuts...brass fittings came apart with torch heat cycles and and PB blaster over and over again...the oil cooler nuts however were a completely different story..no amount of heat or lubricant was going to get these to release..even after cutting them they wouldn't even turn with a wrench. I had to tap the cut portion of the nut with a screw driver and hammer to get them to spin off. Luckily they cleaned up and the threads were not damaged and nothing entered the oil system. If anyone is doing this for the first time, remove the oil cooler from the car once you get the brass line nuts off and it is much easier to attempt to cut the oil cooler nuts off. Cutting those nuts is like doing cataract surgery with a dremmel.
Old 08-16-2011, 07:20 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I need to do this, dremel ready
'85 Carrera Targa
PCA/POC
Old 08-16-2011, 07:56 PM
Weekend Mechanic
vulcan300's Avatar
Wish I had gone with the dremel method in the first place, it would have saved me quite a bit of dough.
Old 08-16-2011, 08:27 PM
na2ub's Avatar
I just did this. Big wrenches and heat did not work. First nut, I used a dremel to weaken the nut, then a chisel to spin the nut. That worked. Next nut, I skipped the dremel part, and used a chisel to make a notch, then spin the nut. That also worked. Point is, you might not have to conduct the hair-raising dremel surgery, and just use a sharp chisel to spin the nut loose. Once I had a decent cut in it, I put the air chisel on it. That worked great, but jumped off a few times, damaging the pos trombone that I was getting rid of anyway. Just be carefull with the air chisel.
Doug
79 SC Targa, 22/29 torsion, ER revalved bilsteins, ER rubber bushings, carrera cooler
Old 08-16-2011, 10:20 PM
D911SC's Avatar
I had to dremel an oil line nut. I made 2 cuts at 180 degrees to each other. I very lightly tapped with a flat blade screw driver and separated the halves perfectly/easily.
I found this easier than the single cut and chisel method. I was too nervous about damaging threads.
1983 Porsche 911SC Zinc Metallic - 3.2SS PMO's, Rennshift, 22/28 TB's, partially backdated interior. 28 month restoration now complete
2010 BMW 135i - Love it.
www.project911sc.wordpress.com
Old 08-16-2011, 11:21 PM
fred cook's Avatar
Stubborn fittings.....
I could not get the oil lines off of the thermostat in my SC, but I was able to remove the ends at the front and engine. So I dropped the thermostat with front and rear lines attached and made this tool to remove the frozen nuts on the thermostat. I supported the thermostat with a 4 foot long pipe wrench and put the plate wrench on the nuts and whacked the wrench with a large ball peen hammer. The wrench is cut from a piece of 1/2" steel plate. It is a fairly tight fit over the nuts and transfers blows from the hammer better that a regular wrench would have done. The nuts came off intact without damaging the threads on the thermostat. Some pics:
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 08-16-2011, 11:48 PM
BoxsterGT's Avatar
Porsche Crest
Here in the Northeast rust belt, when we replace a leaking hose, we never take the risk of damaging the thermostat. Dissimilar metal electrolysis causes the steel nuts to bond with the Aluminum threads.
The nuts are always cut to weaken them with an air cutoff wheel, then soaked with penetrant. After letting them sit overnight, we shock them w a air hammer and a round, blunt nose chisel to knock them loose.
So far, we never had one to damage the aluminum threads.
On those rare occaisions when the hose or the brass line is still good and you must cut off the nut, our friends at Elephant racing have a cool split ring washer for fitting a new M30 nut.
It allows you to save the hose or line and its still less costly than damaging a thermostat.
Len
Old 08-17-2011, 03:24 PM
I'm facing this to address leaks with these hoses but now am worried I'll damage the threads. Just to clarify, the threads don't offer any sealing function in the situation do they? So if I nick one using a dremel it won't result in a leak?
Must just leave them on there and ignore the leak...don't want to have to replace the cooler.
Buck
'88 Coupe, '87 Cab,
'88 535i sold '07 A4 sold, '14 C250 DD
Warren Hall, gone but not forgotten
Old 09-11-2017, 10:05 AM
Flojo's Avatar
why dremel? you don't want to save that rotten line anyway?
just cut at nut-level and now you can acces it nicely with a socket grabbing it 360
Regards, Flo
79 SC - Frankfurt, Germany
visit me on www.facebook.com/911garage
Old 09-11-2017, 10:20 AM
OK...hadn't thought of that! Thanks! I assume lots of PB Blaster in order to make sure the threads don't come off with the nut.
Buck
'88 Coupe, '87 Cab,
Old 09-11-2017, 11:09 AM
Flojo's Avatar
in 99% they wont.
if yes, the lines have more serious probs to adress.... and there are repair adapters that cut over the humps (as seen on fvd-brombacher.de)
Regards, Flo
Old 09-11-2017, 11:19 AM
Send a message via AIM to brighton911
The absolute best penetrant I have found is a mix of acetone and ATF (automatic trans fluid). I had my trombone cooler off today in prep for a real cooler. Dripped some of the mixture on the fittings, waited 10 minutes, a touch of heat from a propane torch and both came loose like they were installed yesterday.
1986 Targa Guards Red
2012 Cayman S
Old 09-11-2017, 05:01 PM
Was looking this tonight and the hard lines are really close together...wll be hard to get a wrench in there to get the other end off, not to mention the ones on the oil cooler end. Is acetone something I can find at Pep Boys or O'reilly's? I've heard about ATF being good for this.
Buck
'88 Coupe, '87 Cab,
Old 09-11-2017, 05:57 PM
That Guy
Techno Duck's Avatar
Replacing fender mounted oil cooler lines pictorial
Sorry the pictures are dead, photobucket sucks!
Using a dremel with a cutoff wheel is how i had to get my lines off. Cutting the nuts is easy, dont be too concerned about cutting into the threads on the cooler... if you go slowly you will barely nick them. The threads are simply to tighten the nut, they do not seal anything.
Jon - San Diego PCA #516
1988 Granite Green 911 3.4L
2017 Reflex Silver Mk7 GTI
Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1, 1997 E36 M3, 2003 E39 540i
Old 09-11-2017, 06:18 PM
That Guy
I updated that thread with a photo dump of the original pictures...
Old 09-11-2017, 06:22 PM
Jon, thanks a million, those pics are VERY helpful! The other parts and their specific #s are particularly helpful.
Buck
'88 Coupe, '87 Cab,
Old 09-11-2017, 07:36 PM
