Woo HOO, The Motor is in....
I'm dead tired. About ten Minutes ago (1:30 AM) Me and two buddies just finished putting my newly rebuilt motor back in my car. I spent the day putting it all back together and around 7:00 PM they came over and we put it in. After cranking for a few seconds, then realizing that I had mixed up the referance and the speed sensor, a quick switch was made and it fired right up. What a great feeling. Even better, I took the motor out, tore it down, rebuilt it myself (under the watchful eye of a pro mechanic) and it runs,,,who whoulda thunk it.
For those interested in the costs, they broke down as follows: Machine work, $405 This included magnafluxing the crank and rods, resizing and rebushing the rods, micropolishing the crank, checking the case and a complete balance of the Rods, pistons, flywheel and crank new chains and ramps, gaskets sets, main and rod bearings $600 New reference and speed sensors, head temp sensors $270 reground cams from Webcam $500 New 98MM P/C's $1800 Twin plug heads w/EBS racing springs and Titanium retainers (I've had these for awhile sitting on the shelf) Paid $2000 for entire twin plug setup which including distribitor and two sets of wires, fresh heads with the springs, the andial splitter, modified sheetmetal and lower valve covers for the twin plug. ARP rod bolts $185 Motor firing up after a very long day....PRICELESS:) I really enjoyed working on the motor and would suggest it to anyone considering it. Thanks to all those that gave me advice, I really appreciate it. |
Mike, I am cracking my 3rd beer tonight in honour of you :)
Enjoy your new motor and take plenty of track photos! Goodonyamate! |
Great..... Just put my Bottom end together this past weekend...
Would have got P&C's on but had the wrong size rings.... Needed 4mm instaed of 3.5mm on the oil ring.... Very happy we caught it.... |
Good job Mike....
Best of luck buddy...hope you take home lots of bacon with the newly configured "hotrod"...:D
Congratulations, Mike! Tear 'em up.
Way to go Mike. I can't wait to see it in action.
you give me hope for my engine!!!
BTW where did you get the Mahles?? Thanks MJ |
Mike,
Yes where did you get a new set of P/C`s for $1800! And how about the twin plug set up. Is it the Andial modified unit? More detail please.......enjoy. Tinker |
Congrats Mike!!! Isn't it a good feeling to be exhausted from such a productive endeavor?
It was great seeing you at Willow Springs on Sunday. Wish we could have grabbed a beer and talked racing some more. So, which of the 150 different pieces of motor break-in advice are you going to follow? ;) Good luck with it!! |
Twin Plug Setup
So, where or how do you get a twin plug setup? Do you just modify your existing heads, or are pre-modified heads available somewhere?
SS |
good job mike,
hope mine starts when its done:eek: |
Congratualtions Michael. Man, that has to be one of the great feelings in life....having that engine fire and run for the first time!:)
| All times are GMT -8. The time now is 05:44 AM. |
