-   -   Carrera Airflow Meter test question (http://forums.pelicanparts.com/porsche-911-technical-forum/624110-carrera-airflow-meter-test-question.html)
Tippy 08-11-2011 07:34 AM
Using the 9-volt battery test, in the first 5-10 degrees of travel, the voltage would not increase at all. Then, after I get past that point, the voltage would jump about 0.3 to 0.4 volts higher.
Is this normal or not?
aston@ultrasw.c 08-11-2011 10:45 AM
no, no jumps in voltage
a smooth and steady increase as the flap is opened.
Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk* ©2001 www.the944.com
Tippy 08-11-2011 10:53 AM
So, I replaced the AFM with another one and my symptoms are still present. That is when I thought maybe the flat spot was intended at idle if you will.
aston@ultrasw.c 08-11-2011 10:56 AM
If you look at the curves in the AFM link, the shapes are slightly different but none have a .3V step.
This matches my experience.
Tippy 08-11-2011 10:59 AM
On the "1986 AFM map", there is a flat-spot in the first so-many-degrees.
That is where I am confused
aston@ultrasw.c 08-11-2011 11:01 AM
I have measured the actual AFM voltage with the car running at idle (by splicing into the wiring harness.)
The AFM voltage changes a small amount as the idle speed is adjusted.
aston@ultrasw.c 08-11-2011 11:04 AM
It may be flat but the transition is smooth, there is no step.
look how much the line would deviate for a .3V step
Tippy 08-11-2011 11:13 AM
Ah yes, very true.
I guess I should look at the values a little more and not the curve.
