-   -   Gained a few MPG in the SC with a simple fix! (http://forums.pelicanparts.com/porsche-911-technical-forum/624117-gained-few-mpg-sc-simple-fix.html)
tyro 08-11-2011 08:08 AM
Car is an '80 SC, RoW version.
Followed the very helpful instructions in the link below to service my distributor. Found my vac advance frozen and total timing under spec.
Went from the usual 17-18 MPG to as much as 23 MPG. Could have done this long ago and might have had some extra $$ for Porsche parts. Feeling a bit stupid!
Make sure to have a new distributor o-ring handy.
http://forums.pelicanparts.com/porsche-911-technical-forum/333640-distributor-service-clean-lube-real-easy-without-removing-pinion-gear.html
scotricker 08-11-2011 08:56 AM
Awesome! Thanks for the link, too. I should do that just to see what kind of grime is in there. Another to-do list item.
Josh D 08-11-2011 09:34 AM
Thanks for the reminder! Something to add to the list to do when it finally cools off a bit!
