-   -   Skid Wheels to prevent scraping (http://forums.pelicanparts.com/porsche-911-technical-forum/624177-skid-wheels-prevent-scraping.html)
Flieger 08-19-2011 09:26 PM
Well, I am looking at operation within design parameters. These are not intended to touch down at any sort of speed. It is for crawling up steep driveways without scraping stuff. Sounds like a good design to me.
The key is just making sure it does not touch down in other areas of driving. So stiffer torsion bars.
Jack Olsen 08-19-2011 10:37 PM
I really liked the JMPRO ones I tested. But my car is pretty low, and I did get contact with the road in extreme compression (fast driving through a dip or elevation change in the driving surface). It would have worked if they'd been shorter, but that illustrates the problem of designing something like this what will work with an assortment of 911s with different ride heights and spring rates.
Brorag 08-20-2011 07:53 AM
Philistine!!!!!!!!!!!!
I know I'm messing with the minds of the purists, and apologise for being such a philistine. If all goes well, such a mod will never have to be be used.
But there is apparent interest, judging by the # of views. So, with apologies to Tennyson:
Hoots to the left;
Hoots to the right,
Onward he came.
Was the Pelican dismay'd?
Not tho' the Pelican knew
He had possibly blunder'd:
His not to make reply,
His not to reason why,
His but to do and die:
Into the valley of Death
Rode the philistine.
If this doesn't work, and I am still alive, I'll be the first to say so.............:D
moneymanager 08-20-2011 08:22 AM
I think the wheel idea is dumb. Just what you need, 2" less ground clearance. And when the wheels catch on the edge of a ditch, something really ugly is likely to happen.
Perhaps a Subaru would be a better transportation choice?
kach22i 08-20-2011 09:18 AM
Milt, are you suggesting a skid-plate such as used on Rally Cars and Off-Road trucks?
Rally Armor FAQs
http://www.rallyarmor.com/store/imag...ate_unbolt.jpg
http://www.rallyarmor.com/store/imag..._mud_flaps.jpg
"Panzer Plate" heavy duty aluminum skid plate kit for 1998-2010 New Beetles
Panzer Plate heavy duty aluminum skid plate kit for 19982010 New Beetles by www.dieselgeek.com
http://www.dieselgeek.com/catalog/BottomView.JPG
Also, the New Beetles are very low to the ground and the front springs on these cars are relatively soft which causes the cars to bottom out frequently. Damage often occurs when bottoming out. In addition, the plastic belly pan that comes with these cars is often damaged. A replacement New Beetle TDI factory plastic belly pan currently costs up to $337.00. Why replace it when you can buy an indestructible aluminum skid plate? Installing our hefty .190" inch thick aluminum skid plate will help you avoid costly repairs and give you peace of mind that your engine is protected! Take a look at these pictures:
Lexus Gx470 Skid Plate View Photo 4
http://image.fourwheeler.com/f/90935...plate_view.jpg
Sliced bread, anyone? We stole a trick from the rock racers and made our front skidplate from 1/2-inch cutting-board plastic. This is the same stuff that bread cutting boards are made of. It works amazingly well, sliding over every rock it comes in contact with. So far it has held up very well to TraiLex's 5,500-plus pounds of mass bearing down on it. It has definitely been used, as the Lex's ground clearance is still challenged by the trails we've driven it over. View Related Article
Read more: Lexus Gx470 Skid Plate View Photo 4
Bottom plates for racers and people looking to save gas by smoothing out the airflow under the car are common enough.
Brorag 08-20-2011 09:27 AM
dumb is as dumb does
JH,
I know. There's just no excuse!!!!
I've driven all around your part of the country, and if memory serves, you've got relatively smooth roads, except when the earthquakes hit.
The fix I'm adding will use up less ground clearance than these,
and are about .5 " less than the original tiedown before they're all bent out of shape. (see earlier pic).
I've tried the Spoiler Protection Skid Plates and they offer good protection for most applications. I'm just taking it the next step.
Not to worry, all will be well.
Just remember my credo: I have more ass than you have teeth....................:D
On the other hand, if you happen to hear a loud explosion east of you, it might be NC exploding cause I PO'd the Porsche gods.
sc_rufctr 08-20-2011 10:00 AM
OK, Just throwing this out there...
What about small air bags to lift the front of your car?
So you get to your drive way. Hit a switch and they raise about 40mm or 50 mm so you can drive in without scraping your car.
I've seen modified struts advertised for the later water cooled 911s. They have a small air bag between the spring and the perch.
I'm not sure how you would set them up on our cars. Maybe between the body and suspension arm? It would have to be small to fit.
Brorag 08-20-2011 10:39 AM
well, sheeeeeeeeeeeeeeee it!
Peter,
sounds like a good idea for predictible type transitions. In this case, the driveway is not an issue. On occasion, these cars bottom out. All you have to do is look at your tiedowns on the front a-arm covers. Betcha their bent. what this does is provide a rolling transition across an obstacle that would have bent the tiedown. The ride height of the resulting gizmo is actually~.5" higher than the original tiedown.
............on the other hand..............
How hard can it be? I mean, what could possibly go wrong? I can do better'n that! Reactive armour!!!!!!!!!!!
Each panel measures about 250 x 150 x 70 mm and has four bolt holes, one at each corner, to attach one brick to each corner. Located centrally on the edge of each brick is a pair of mounting pins enabling it to be attached to the tank's main armour. Attach to front of a-arms. Bottom out and BOOM!!! Your car is gently lifted right over those pesky bumps!!!!
http://forums.pelicanparts.com/uploa...1313861868.jpg
this just keeps getting better & better................ass check: yep, still there:D
Zeke 08-20-2011 12:05 PM
I wasn't planning on having the skid plate shear off and expose the rubber mount. The rubber is to lessen the impact and the plate is to provide something to protect the rubber. The hockey puck is s good idea. A half moon mounted vertically would be a good design.
A steel roller is going to be prone to damage and the impact will be the same as hitting the tow hooks and/or condenser bar. We all know that's pretty harsh.
911pcars 08-20-2011 12:21 PM
How much are hockey pucks?
The ideal sacrificial material should be:
cheap
quiet
long lasting (relatively)
Sherwood
kach22i 08-20-2011 12:48 PM
You are making a hovercraft lift fan with bow skirt seem like an attractive alternate.
karlo | – Kit Speed — Build It –
http://www.landrovermonmouth.com/ass...Hovercraft.jpg
Brorag 08-20-2011 05:34 PM
progress report
OK, I've removed the front a-arm covers, and completed the welding and drilling.
weld, with angle set to make the wheels ride about level
http://forums.pelicanparts.com/uploa...1313886594.jpg
front shot showing angle set to compensate for angular installation
http://forums.pelicanparts.com/uploa...1313886648.jpg
back shot weld job. Could have made it a lot neater, by spending the time grinding and filling.
http://forums.pelicanparts.com/uploa...1313886691.jpg
etching primer front
http://forums.pelicanparts.com/uploa...1313886732.jpg
etching primer back
http://forums.pelicanparts.com/uploa...1313886770.jpg
black paint corrosion control
http://forums.pelicanparts.com/uploa...1313886804.jpg
I'm beat, and my electrolytes are dangerously low--time to replenish them with spiritus fermenti.
Will install tomorrow. Pics and test drive to follow.
sc_rufctr 08-20-2011 08:38 PM
Well that's something and it looks like it will do the job. Cred to you for having a go.
Your set-up would have to be better than nothing at all.
Just a thought. It may be better to have the wheels mounted in such a way so that if they hit something "hard" they would break off rather than bend the pan.
Your design is fine... You could carefully cut away some material to weaken them a bit. (50%)
It's just a suggestion, do what you want. It's your car... Good luck with your design.
Brorag 08-21-2011 10:07 AM
installation
Got up this AM and had traditional southern breakfast of fricasseed frog lips and grits with redeye gravy, and washed it down with some fresh 'shine!. Yummy..
The A-arm cover re-installs as before:
http://forums.pelicanparts.com/uploa...1313945976.jpg
Access hole to front bolt position. Center the hole as best as you can--I could have done better--drill at an angle to match installation angle of bolt:
http://forums.pelicanparts.com/uploa...1313946037.jpg
Make sure the 17mm socket you will use will fit into access hole.
  • I had originally planned to use a hex-head, but couldn't find one in the whole frickin town, so I went to plan B.
  • If you can find something with a smaller head size, then your access hole can be correspondingly
    smaller--more strength....
http://forums.pelicanparts.com/uploa...1313946096.jpg
The front A/C condenser protective bar had done it's job, and suffered as a result. I suggest that you eyeball fit the bar before trying to re-assemble, as it may be bent from taking bumps. This one was bent, and I had not dry-fitted before re-assy. It came to rest about 1.5" below where it was to be attached, and the bolt would not align to pull it tight.
http://forums.pelicanparts.com/uploa...1313946219.jpg
I used a jack and spacer to position the condenser protective bar, then mounted the bracket.
http://forums.pelicanparts.com/uploa...1313946281.jpg
Mounted bracket, showing angle correction so that wheels are parallel to ground. Remember that the bolts align at an angle for proper fit. Suggest using a screwdriver to get mental picture of angle before screwing in bolts.
http://forums.pelicanparts.com/uploa...1313946350.jpg
Mounted wheel. Note color. I used it to provide contrast, corrosion control, and to add a certain je ne sais quoi...................besides, it was the only color I had in the shop.
http://forums.pelicanparts.com/uploa...1313946409.jpg
I used lots of grease and tightened the lock nut till it squeezed the wheel , then backed off till the wheel turned. Also added extra washers as spacers.
http://forums.pelicanparts.com/uploa...1313946462.jpg
There has been lots of discussion and expressions of concern about the wheel compounding the problem if you scrape the bottom of your porsche, and they are valid concerns.
But, if you compare the ground clearence of the installed wheel to:
  • the ground clearence of the tiedown
  • to the tie down with the aftermarket scrape plates installed
this installation allows:
  • at or more ground clearance than the tie downs
  • over .5" more clearance than the aftermarket scrape plates
http://forums.pelicanparts.com/uploa...1313774910.jpg
The proof is out there, waiting to be discovered in the real world ...........
Next...go thrash the living buggers out of the wee beastie and field test the design.:D
JMPRO 08-21-2011 12:21 PM
Watch the axel nuts . They have a habit of coming loose when used in the way you have it. That is why I used pins for axels instead of bolts. Also for ease of changing the wheels if necessory.
Jerry
Brorag 08-21-2011 01:09 PM
JMPRO,
Thanks, I'll keep an eye on the nuts.
I might just swap out anyway to be on safe side.
JD
DUK 08-21-2011 02:45 PM
Very nice John. We can hopefully try them out this weekend.
kach22i 08-22-2011 07:27 AM
Now you need to mount a video camera down there so we can see them in action.:cool:
Nice work.
I think if I ever revisit this topic I'll be installing a HDPE sheet like the ecomodders do to increase gas mileage. Problem then will be the attachment points and how large, and where to stop the sheet. I'm thinking the cross over cover hiding the fuel pump as the back end. Attaching to the underside of the chin spoiler for the front would be idea, but would not be secure enough on impact and would cause spoiler damage.
Covering the whole bottom is always an option, right?
http://forums.pelicanparts.com/porsche-911-technical-forum/294153-poor-mans-aero-wingin-7.html
http://forums.pelicanparts.com/uploa...1154096927.jpg
Good PDF on underbodies:
http://sports.racer.net/docs/aero/rva2002_gr02_underbody.pdf
http://forums.pelicanparts.com/porsche-911-technical-forum/182467-poor-mans-ground-effects-i-need-some-input-4.html
http://forums.pelicanparts.com/uploa...1095510399.jpg
Brorag 08-24-2011 11:44 AM
Duk, where/when to meet?
Kach, if you do something like that, would there be any way to measure before and after to see if it significantly reduced drag?
JD
kach22i 08-24-2011 12:40 PM
JD
The stuff they sell on the EcoModder website to estimate fuel mileage is for 1996 cars and newer. So, I'm out of luck there.
EcoModder Store: Get Stuff, Support EcoModder - EcoModder.com
I can get 26 mpg mostly highway with the top on and doing 70 mph. However the commute I did a couple of years ago to get that figure is not likely to be part of my life again.
I'd have to do a couple of fill ups and controlled runs before and after such a modification to get a good idea. Would be far from perfect though.
I have to imagine that a lot of track guys already have done something similar (not just Jack Olsen). They might know already what to expect. I suspect they use the lightest materials (thin sheet aluminum), and maybe not the heavier HDPE.
NOTE: the 26 mpg was with sticky but low height 50 series summer tires. I now run higher profile 60 series all-season tire, sitting over 3/4" higher. Between the harder tire compound and increased amount of air getting under the car, it should be the same 26 mpg, but I'm not sure.
Brorag 08-25-2011 09:28 AM
field test results
I was taking the wee beastie back to the ragtop guy to do final adjust, and hit a pothole. The car bottomed out and the wheels struck the surface. I could hear/feel the strike. The car remained under control. Exam'd the wheel and environs and found no damage. Paint scraped off wheel contract area ~1/16th ". No bent noth'n.
It works.
Eugene at Pelican Parts 08-25-2011 10:45 AM
How loud was the sound compared to scraping metal? I was never fond of the attention drawn from scraping driveways--especially when it's not your own.
It works.
Brorag 08-25-2011 03:56 PM
not loud
just a dulcet bump, no scraping--it rolled. I was the only one that noticed it. It took me over the obstacle and that was it. Why don't you get Wayne to start making them? All I want is a small percentage:D
70SC 08-25-2011 04:07 PM
Nice shopping cart :eek:
Brorag 08-26-2011 05:48 AM
Shopping cart? No, much better............
did you see the pic where we used it for a firewood cart?:D
http://forums.pelicanparts.com/uploa...1314362906.jpg
kinein 08-26-2011 06:16 AM
wheel
yep i knew a guy who had one on his 83 slant nose the casters where a hard plastic wheel.....i thought it was a brillant idea for a lowered 911 for driveways and what not....
Originally Posted by Brorag (Post 6190999)
Has anyone had any experience using something like these to prevent your lowered porsche from bottoming out?
http://forums.pelicanparts.com/uploa...1313095458.jpg
kach22i 08-26-2011 07:21 AM
Originally Posted by Brorag (Post 6219038)
You have put a lot of work into your car, looking good now.:)
HelmetHead 08-26-2011 07:58 AM
How about something like this using the front mounted spare tire :D
<object width="450" height="370"><param name="movie" value="http://www.liveleak.com/e/399_1305599171"></param><param name="wmode" value="transparent"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.liveleak.com/e/399_1305599171" type="application/x-shockwave-flash" wmode="transparent" allowscriptaccess="always" width="450" height="370"></embed></object>
911pcars 08-26-2011 09:09 PM
Just to review. There's no difference between bottoming out on a rigid caster wheel and bottoming out on the underside of the chassis. If a caster wheel hits something, like a bump in the road, it's the same impact on the chassis, despite the fact it can also roll after the initial impact.
Sherwood
Flieger 08-26-2011 09:15 PM
Point being? Skid plate would have the same impact as well.
911pcars 08-26-2011 10:40 PM
Understood. However, discussion seemed to veer toward protecting against bottoming out by adding stuff to the underside. All that does is decrease ground clearance and increase risk of bottoming out.
Slowly negotiating a driveway is something else. A skid plate is fine except for the noise it creates.
S
Flieger 08-27-2011 10:44 AM
Yeah, I would probably just try to change lanes around the potholes but then I don't live there so it might not be possible. Then I would try to go slower.
Variable ride height like the KW kit for late model cars would be nice.
For driveways, the wheels look like a great solution. No scraping noise (or at least not as much) and no hard impacts.
Brorag 08-27-2011 11:37 AM
thanks, Kach..........
Roadtrip!!!!!!!!!!!!!!
Helmethead, sounds like another project!
Remember, most pioneers have more a$$ than the injuns got teeth.....................
Flieger 08-27-2011 11:38 AM
? more info please
Brorag 08-27-2011 11:48 AM
getting itichy
Don't know, Flieger...............time to get the wee beastie on the road.
JD
kach22i 08-27-2011 12:49 PM
Cool, rotate in one direction in "D", rotate in the other direction using "R".
I wonder how many beers it took to come up with that idea. I cannot argue with something that works, and that works.:)
Edit: Would this last long on the street?
http://www.vividracing.com/blog/announcing-new-products-specials-and-info/apr-carbon-fiber-splitter-for-mitsubishi-evo-x-released/
http://www.vividracing.com/catalog/w...rsplitter5.jpg
http://www.vividracing.com/catalog/w...ndsplitter.jpg
Brorag 09-12-2011 09:42 AM
It might be too low...........................
This is better than watching the soaps..........or having a bad case of athletes feet............it just keeps on going....................
http://forums.pelicanparts.com/uploa...1315845636.jpg
All is well till I take a right curve uphill at speed, then the spoiler in front of the drivers wheel scrapes.
Back to the front end, and up it about 1"--use weights to account for load.
Brorag 09-14-2011 11:22 AM
Just what is the best ride height?
After a suspension rebuild and alignment, I found that when driving in the mountains, the part of the spoiler in front of the drivers front tire scrapes occasionally when engaging a sharp uphill corner turning either left of right.
Maybe I've got this thing too low?
No, no more wheels.................
I started searching and came across this thread
Code:
fender height measured through wheel center
        rear        front
        25        25
        24        24.5
        24.25        24.5
        24.25        24.75
        24        24.5
        25        25.25
        25        25.5
        25        24.5
        25        24.5
        25        25.5
        25        24.6
        24.25        24
        24        24.5
        24        24.75
        24.25        23
        23        25.5
        25        25.5
total        416        420.35
avg        24.471        24.726
in real #'s        24.5        24.75
my car        24        25.3
Gotta go off and think.................
Ideas?
wayner 09-14-2011 12:25 PM
I just stop and pick up a hitchhiker and have them sit on the whale tail for particularly bumpy sections of road. :-)
j911brick 09-15-2011 02:17 PM
Originally Posted by Brorag (Post 6192263)
My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives...................................... .................
Blazing Saddles...
