field test results
I was taking the wee beastie back to the ragtop guy to do final adjust, and hit a pothole. The car bottomed out and the wheels struck the surface. I could hear/feel the strike. The car remained under control. Exam'd the wheel and environs and found no damage. Paint scraped off wheel contract area ~1/16th ". No bent noth'n.
It works. |
How loud was the sound compared to scraping metal? I was never fond of the attention drawn from scraping driveways--especially when it's not your own.
not loud
just a dulcet bump, no scraping--it rolled. I was the only one that noticed it. It took me over the obstacle and that was it. Why don't you get Wayne to start making them? All I want is a small percentage:D
Nice shopping cart :eek:
Shopping cart? No, much better............
wheel
yep i knew a guy who had one on his 83 slant nose the casters where a hard plastic wheel.....i thought it was a brillant idea for a lowered 911 for driveways and what not....
How about something like this using the front mounted spare tire :D
<object width="450" height="370"><param name="movie" value="http://www.liveleak.com/e/399_1305599171"></param><param name="wmode" value="transparent"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.liveleak.com/e/399_1305599171" type="application/x-shockwave-flash" wmode="transparent" allowscriptaccess="always" width="450" height="370"></embed></object> |
Just to review. There's no difference between bottoming out on a rigid caster wheel and bottoming out on the underside of the chassis. If a caster wheel hits something, like a bump in the road, it's the same impact on the chassis, despite the fact it can also roll after the initial impact.
Sherwood |
Point being? Skid plate would have the same impact as well.
Slowly negotiating a driveway is something else. A skid plate is fine except for the noise it creates. S |
Yeah, I would probably just try to change lanes around the potholes but then I don't live there so it might not be possible. Then I would try to go slower.
Variable ride height like the KW kit for late model cars would be nice. For driveways, the wheels look like a great solution. No scraping noise (or at least not as much) and no hard impacts. |
thanks, Kach..........
Roadtrip!!!!!!!!!!!!!! Helmethead, sounds like another project! Remember, most pioneers have more a$$ than the injuns got teeth..................... |
getting itichy
Don't know, Flieger...............time to get the wee beastie on the road.
JD |
I wonder how many beers it took to come up with that idea. I cannot argue with something that works, and that works.:) .................................................. .......................................... Edit: Would this last long on the street? http://www.vividracing.com/blog/announcing-new-products-specials-and-info/apr-carbon-fiber-splitter-for-mitsubishi-evo-x-released/ http://www.vividracing.com/catalog/w...rsplitter5.jpg http://www.vividracing.com/catalog/w...ndsplitter.jpg |
It might be too low...........................
This is better than watching the soaps..........or having a bad case of athletes feet............it just keeps on going....................
http://forums.pelicanparts.com/uploa...1315845636.jpg All is well till I take a right curve uphill at speed, then the spoiler in front of the drivers wheel scrapes. Back to the front end, and up it about 1"--use weights to account for load. |
Just what is the best ride height?
After a suspension rebuild and alignment, I found that when driving in the mountains, the part of the spoiler in front of the drivers front tire scrapes occasionally when engaging a sharp uphill corner turning either left of right.
Maybe I've got this thing too low? No, no more wheels................. I started searching and came across this thread Code:
fender height measured through wheel centerIdeas? |
I just stop and pick up a hitchhiker and have them sit on the whale tail for particularly bumpy sections of road. :-)
| All times are GMT -8. The time now is 05:58 AM. |
