head retorque ?
can the heads be re-torqued with engine still in the car?
thanks Sutton
sutton |
Air Medal or two
yes but why? checking for broken studs ?
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
I've only checked them 500 miles after a rebuild and at a few thousand miles
there shouldn't be a reason to retorque and text book retorque could mess up your engine if anything it a good way to see if they're pulling out of the case if you only tighten I'm not a pro
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
