CT Mike's Avatar
Stripped hex nut
Wanted to remove the seats today in my 88 targa and found one of the hex nuts is stripped. The wrench catches in the direction of tightening but doesn't the opposite way. Aside from trying to grind a slot with my dremel tool does anybody have a good trick to fit it? Thanks.
Old 08-13-2011, 12:06 PM
1988 Carrera
shadowjack1's Avatar
I used a chisel and a hammer on mine. You can hammer the chisel into the top at an angle and spin it off. You will have to replace the bolt. It worked for me.
Old 08-13-2011, 12:22 PM
steely's Avatar
Craftsman Bolt-out set with a hand impact driver. Worked a miracle for me once.
Stripped allen bolt head (not threads)
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 08-13-2011, 12:26 PM
UnRegistered User
billybek's Avatar
Try filing the allen hex key to ensure you have a good bite with no wear on the bit.
Wet the bit and dip it into a powder type cleanser like Comet then put it into the socket of the bolt.
The cleanser may offer enough bite to get it loose without getting all Medieval on its *ss!
Cheers!
Bill K.
Old 08-13-2011, 04:32 PM
fred cook's Avatar
Stripped bolt......
If the powder trick doesn't work, try epoxying the wrench into the bolt with some JB weld. Let dry overnite. That should give you enough grip to loosen the bolt. If you spray the allen wrench with oil before setting it in place, you should be able to wriggle it out of the bolt once it is loose.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 08-13-2011, 05:54 PM
Diss Member
Quicksilver's Avatar
Need to make sure there is enough room for the allen wrench to spin around 360 degrees before JB welding it in...
You can JB weld an allen driver in and then use a ratchet on it...
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 08-13-2011, 09:58 PM
Capitalist and Patriot
911Freak's Avatar
One of the bolts in my SC was like that, fortunately I was able to double nut the bolt from the underside and back it up and out enough to grab it with vice grips and remove it. Not sure if it was a factory bolt but I noticed each seat had a pair of these longer bolt....
Good Luck
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 08-13-2011, 10:15 PM
faverymi's Avatar
I have a cheapo welder that helps me tack weld stripped hardware.
I have a set of cheap china sockets, allen, that I cut, weld,modify to take anything out.
You know how rusty get in the northeast.
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 08-14-2011, 05:52 AM
