77 911s blower motor - Eng compartment
Hi there
Orig blower motor inop, removed, tested with 12 volts, no action, disassembled, cleaned, brushes good, reassembled, applied 12 volts, still no action 🤔 So - ordered new motor from Pelican, received couple days ago, applied 12 volts to the 2 leads - and nothing! Switched leads, nothing ☹️! Ok what am I doing wrong 🤔 Gary in Marietta ga. |
I am sure you are grounding the motor when you apply 12 volts?!
Still here
Are you saying you applied 12V across these terminals and the motor's dead ?
Yes
Still here
Sounds like the motor's DOA.
