Fuel acumulator drain screw leaking
Found fuel leaking on the small screw on the bottom of my acumulator. Can I mearly seal the leak with locktite or thread sealant or replace the acumulator. The 1974 911 2.7L runs fine, starts up in all conditions. Thanks.
1974 911 2.7L coupe with sunroof |
It usually means the rubber diaphragm has a hole, and the whole unit needs to be replaced
Al Shkuratoff 86 Carrera, SW chip, Fabspeed, M&K 83SC Platinum - Sold 83SC Slate Grey - Sold |
