-   -   Engine test stand?? (http://forums.pelicanparts.com/porsche-911-technical-forum/625058-engine-test-stand.html)
patkeefe 08-16-2011 04:01 PM
Engine test stand??
Anyone have an engine test stand, for bolting up the engine to run on? In the old days, we had a Stuska dyno. I want to build a stand to run new engines on...just want some ideas of what's out there. I can go either engine only, or engine/trans mated, which may be easier.
TIA!
Pat
al lkosmal 08-16-2011 05:00 PM
Porsche EFI kit - fire up - YouTube
Slightly modded V8 test stand..........bought it at costco five years ago or so for $300.
regards,
Al
sailchef 08-16-2011 05:19 PM
regards,
Al
I played that video twice just to listen to the engine purr............sweet!
donporfi 08-16-2011 05:39 PM
Check this test stand, it is very simple and can do the job. You can buy it or build it.
Engine Test Stand for Air-cooled Porsche and VW
A friend built a test stand to start up 356 and VW engines, he is using an empty gearbox. I will post pictures later.
I think you are not looking for a dyno to load the engine. If you are, there are plenty to choose from.
donporfi 08-16-2011 05:50 PM
Pictures of two 4 cylinder test stands.
This is the one my friend built
http://forums.pelicanparts.com/uploa...1313545706.jpg
I found this one in the Pelican Forum
http://forums.pelicanparts.com/uploa...1313545749.jpg
boyt911sc 08-16-2011 07:18 PM
Engine test stand......homemade
TIA!
Pat
Pat,
I got one made from scrap metals I found at home few years ago and have been using it successfully. I spent less than $30 to complete the project (test stand) plus accessories (battery, oil tank, CDI, fuel tank, etc.). I posted several pictures in this forum for people see it as an inexpensive way to have one.
Tony
patkeefe 01-27-2012 05:45 PM
I'm building one
So, I picked up some 1-1/2" tubing, and found a couple of old display racks at work which were built with 3/4" square tubing. I'm building a full stand to carry an old 901 914 transaxle which has been gutted. I'll make the trans permanent on the stand. Now, if I can just find a cheap water absorption brake unit...
Base and trans posts:
http://forums.pelicanparts.com/uploa...1327718646.jpg
Test 2.4 case with the gearbox mounted:
http://forums.pelicanparts.com/uploa...1327718524.jpg
Don't forget what your Porsche really is:
http://forums.pelicanparts.com/uploa...1327718570.jpg
patkeefe 01-30-2012 04:31 AM
Progress is slow
Well, I can't see to weld as good as I used to, and I did set myself on fire yesterday (I survived unharmed; don't weld in cotton flannel jackets!). The good news was that I only burned up the jacket pocket that was already ripped.
Test fit of gearbox:
http://forums.pelicanparts.com/uploa...1327930022.jpg
http://forums.pelicanparts.com/uploa...1327930044.jpg
http://forums.pelicanparts.com/uploa...1327930071.jpg
Battery mount plate. Fuel tank will be on the other side.
http://forums.pelicanparts.com/uploa...1327930141.jpg
patkeefe 02-08-2012 02:46 PM
More photos
OK, here is where we are at. I need to incorporate a battery, fuel tank, fuel pump for my CIS, and ignition, some terminal blocks, the oil tank and a control panel. BTW, I found some old display racks at work, which I glommed. They sure were heavy duty, and had lots of steel in them. Wish we had turbos lying around like that!
For the equavalent of the rear mount bar, I fabbed up this bracket to bolt on. I can't just put a couple of vertical risers on the stand, because there is too much exhaust crap in the way. From the mount carrier to the back of the rear bumper on my SC is approximately 12", and the Flowmaster 44 I have on the turbo takes up about that much room. I left myself about 2-1/2" to spare. This bracket and the unfabbed braces will be bolt on, else I'll never get the engine in.
http://forums.pelicanparts.com/uploa...1328743572.jpg
http://forums.pelicanparts.com/uploa...1328743595.jpg
Battery tray for the Optima. This Optima is 15 years old, and still starts the car. Amazing.
http://forums.pelicanparts.com/uploa...1328743823.jpg
The fuel tank I have is a bit too big to fit. I do have a 3 gallon tank from the blown up emergency generator which is 13" x 20" by about 5" at the deep end. It will fit nicely where the red milk crate is.
http://forums.pelicanparts.com/uploa...1328743958.jpg
I have a brand new Ebay knock off Bosch fuel pump somewhere. I need to find an accumulator and fuel filter setup, which will get mounted by the red milk crate fuel tank.
The Sennecker oil tank is going over by the engine mounted oil cooler. I'll go with an AN-16 gravity feed to a rubber hose to replace the "S" line, and use some AN-12 for the scavenge outlet. I have so many oil coolers on my car that I go through AN-12 fittings like TicTacs. They are cheap if you buy used from the circle track guys on Ebay, just clean them out really good.
http://forums.pelicanparts.com/uploa...1328744365.jpg
Here's the control panel. Wireless!
http://forums.pelicanparts.com/uploa...1328744402.jpg
Anyone got any ideas, feel free to chime in. I can never learn enough from listening to you guys.
Here's some of the stuff that needs to fit on the stand:
http://forums.pelicanparts.com/uploa...1328744643.jpg
http://forums.pelicanparts.com/uploa...1328744686.jpg
Tony, it's almost golf season...
patkeefe 02-22-2012 02:54 PM
Update...post surgical
So, I had to putter slowly, as I had surgery on Groundhog Day. Literally a PITA. So, in my spare time, I got this far. So far, I have used only stuff I've had lying around the garage. I'm starting to get a bit out of control.:eek:
Primer and Paint, Safety Yellow
Fold away oil tank:
http://forums.pelicanparts.com/uploa...1329954443.jpg
http://forums.pelicanparts.com/uploa...1329954479.jpg
Fuel tank from the blown up Chinese generator, mounted under the transaxle. Fuel pump is my spare Ebay special unit.
http://forums.pelicanparts.com/uploa...1329954619.jpg
http://forums.pelicanparts.com/uploa...1329954646.jpg
911pcars 02-23-2012 07:01 PM
Mounting the gearbox with the engine presents add'l structural and space considerations. The gearbox isn't necessary to run the engine. You can just use the clutch housing from a 901/915 gearbox to mount the starter or fabricate a starter housing.
Some pics from Rennsport last year. Modified 6 > 4 cyl. 911 on what looks to be a regular engine stand with brackets added for oil/fuel tank, control panel, etc. The heavier 911 would need more support on the fan end.
http://forums.pelicanparts.com/uploa...1330055547.jpg
http://forums.pelicanparts.com/uploa...1330055624.jpg
http://forums.pelicanparts.com/uploa...1330055642.jpg
Sherwood
HawgRyder 02-23-2012 09:36 PM
A fair sized water pump of the gear variety and a valving system to provide some back pressure would give the engine something to push against if you are worried about RPM run away.
That is all an engine dyno is BTW.
I had a friend that built one...sent the engine to have it dynoed on an expensive unit...then mounted his engine on his own home built dyno...and used the engine to calibrate the valving and flow to give the correct curve.
Seemed to work quite good.
Bob
patkeefe 03-04-2012 05:38 PM
Engine on stand
Well, I got the engine out and on the stand. Got some things off the engine which are either in the way, or need to go out for repair. Now, I can fit up the other bracing and stuff I need to be able to run the engine on it.
http://forums.pelicanparts.com/uploa...1330914900.jpg
http://forums.pelicanparts.com/uploa...1330914993.jpg
j911brick 03-04-2012 08:50 PM
Did anybody mention Pelican sells a pre-fabbed unit?
patkeefe 03-05-2012 05:52 AM
Those stands are for building engines on, not for running them on.
boyt911sc 03-05-2012 07:54 AM
Nice job!!!!!!
Pat,
The project is looking better each day. But if I were doing this project, I would add a brace/bracket for the front end side of th engine to reduce the stress/cantilever effect of the heavy engine on the transmission bell housing. Your set-up is very common on VW engines test stands but not on the big and heavier 911 engines. Since I have limited working space, I opted for a more compact set-up by eliminating the 915 transmission during test.
This is an example of a test stand posted in the forum. Notice the vertical support on the left side?
http://forums.pelicanparts.com/uploa...1330965599.jpg
This is my home-made contraption and has been handy for the last 12 years. But after seeing your work, I got jealous and would start fabricating something more attractive for show & tell. I wish I could weld as well as you do.
http://forums.pelicanparts.com/uploa...1330965701.jpg
http://forums.pelicanparts.com/uploa...1330965720.jpg
Your engine stand is built to last and looks great. Keep the good work going. Keep us posted.
Tony
j911brick 03-05-2012 08:13 AM
look harder.
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=ZLX-ENG-STND&catalog_description=Engine%20Test%20Stand%20f or%20911%2F930%20%281965-86%29%2C%20912%2C%20914%20air-cooled%20motors%09
patkeefe 03-05-2012 08:29 AM
Originally Posted by j911brick (Post 6602151)
look harder.
I don't know how you found that, but you are absolutely correct! My search skills are slipping. But, I am saving $629 doing it this way.
Tony:
I had to put my SC engine up on the stand to figure out where I can put the vertical stabilizer bars for the nose of the engine. It was too hard to figure bracing location while it's in the car, with the turbo mounted, and the muffler on. I am going to work on that this week, while I wait for parts.
I will be down soon with the Mizunos, BTW...couple of weeks.
NeedSpace 11-19-2013 09:50 AM
Pat,
This is great, thanks for posting. Just curious, I noticed there are no shocks or bushings for the engine to mount to your stand, how is the vibration on this? Does it stay put when running it?
Also, all in, what do you think it cost? I am planning on doing some investigative work to try to track down some oil leaks and thought this kind of setup would work great.
patkeefe 11-19-2013 03:22 PM
need-
I was laid up from surgery, and needed a project. I will figure out what it cost in dollars...I think the most expensive part was the MSD Street Fire, which was about $120. The rest was stuff I had lying around.
The engine doesn't move around. I thought it may try and circle the driveway, but it was stable, and fairly smooth.
I see you're in the lovely Garden State. I'd be willing to let you use it (you may have to leave the 190 as collateral) SmileWavy
