-   -   can this be cleaned up? (http://forums.pelicanparts.com/porsche-911-technical-forum/625205-can-cleaned-up.html)
Cdnone1 08-17-2011 02:42 PM
While checking for an electrical gremlin I decided to remove the fuse blocks from my car. They have some serious corrosion on them but seemed to working fine.
Can these be cleaned up and how would you do it?
http://forums.pelicanparts.com/uploa...1313617181.jpg
http://forums.pelicanparts.com/uploa...1313617209.jpg
http://forums.pelicanparts.com/uploa...1313617234.jpg
http://forums.pelicanparts.com/uploa...1313617261.jpg
http://forums.pelicanparts.com/uploa...1313617289.jpg
http://forums.pelicanparts.com/uploa...1313617317.jpg
The front sides seem fine.
Mitch Leland 08-17-2011 02:51 PM
My 2 cents would be if you don't want to replace them w/ new you could do a very light bead blast on your parts, then as long as you cover up the contact lug holes you could use a rattle can and a clear coat. Also I'm guessing you could wash the parts in baking soda and a brass brush to clean everything. Or a combination of both...
masterdave 08-17-2011 03:25 PM
Im a big fan of this stuff for most metal cleaning
Noxon 7® Metal Polish (6233800117) - Metal Polish & Cleaners - Ace Hardware
It will get rid of, rust, corrosion, dirt, carbon scoring, etc. etc. I use it to clean up all kinds of metal for all different purposes, including electrical stuff.
Best
Dave
dshepp806 08-17-2011 03:46 PM
I'd spend time to rework what you've got,..it certainly CAN be reworked/cleaned. That is, as long as nothing's "loose"...
BEST!
Doyle
86 911 Targa 08-17-2011 03:49 PM
That would be my non-toxic approach also.
skunked 08-17-2011 03:57 PM
30 minutes in evaporust and that corrosion will be gone. Keeping it from coming back is another thing.....
DUK 08-17-2011 06:35 PM
Good old white vinegar will do wonders.
Hugh R 08-17-2011 06:52 PM
Fine emery cloth will work well.
Mitch Leland 08-17-2011 06:58 PM
Cleaning Corrosion...
Great suggestion, I would try this first... Cheap, easy, and non-evasive...
HawgRyder 08-17-2011 08:52 PM
Ultrasonic cleaner?
With the correct water-based fluid...would probably do a good job.
I have used one of those with Tri-chlorethelene 111 in the tank...and heated...it does a fantastic job...and dries almost instantly.
Bob
RWebb 08-17-2011 08:58 PM
vinegar
BUT if you have it all out, why not put in a modern fuse box?
Cdnone1 08-17-2011 09:13 PM
Thanks for the suggestions. I soaked it 50/50 water vinegar and holy crap did that ever do the trick. I will post some pictures of it clean tomorrow.
As for the modern fuse box, I thought about it but this one has worked fine for 30 years and it's a lot less work than mocking up a new one. Now if I can just find my intermittent ground fault on the starter wiring I'll be happy
http://forums.pelicanparts.com/uploa...1313640736.jpg
http://forums.pelicanparts.com/uploa...1313640761.jpg
steely 08-17-2011 10:58 PM
Steve - nice work - look fwd to the pics. One question please, is that oxidation, or did some plating come off of the screws and rear buss jumpers (in the before pics)? And if oxidation, did this do the trick, or did the bath just remove the white fuzz?
daniel911T 08-18-2011 05:03 AM
1. Wire brush
2. A light spray of WD-40
3. Reinstall
4. Don't ever worry about it again. ;)
Look at it this way... in all these years that's as bad as it's got. How many more years will it be before it's a problem again? (hint: many)
Drive, enjoy! :D
-Dan
daniel911T 08-18-2011 05:06 AM
oops
Looks like I was a bit late to the party. :)
Glad you got it sorted out. Vinegar does do wonderful things.
-Dan
Cdnone1 08-18-2011 10:11 AM
Thanks again for all the replies. I soaked them in 50/50 vinegar and water, scrubbed them with an old toothbrush, dried them and sprayed them with a little CRC 2-26. Came out great and hopefully going back in this afternoon
http://forums.pelicanparts.com/uploa...1313687325.jpg
http://forums.pelicanparts.com/uploa...1313687364.jpg
http://forums.pelicanparts.com/uploa...1313687419.jpg
http://forums.pelicanparts.com/uploa...1313687462.jpg
Cdnone1 08-18-2011 11:58 AM
It's all back in
http://forums.pelicanparts.com/uploa...1313693784.jpg
Cdnone1 08-18-2011 12:02 PM
http://forums.pelicanparts.com/uploa...1313694113.jpg
twin plugged targa 08-18-2011 01:17 PM
Nice job-I simply wired brushed and emery clothed mine - but that looks so good I guess its on my winter job list!
- PS my electrical gremlin is STILL not solved!
JJ 911SC 08-18-2011 04:55 PM
Originally Posted by Cdnone1 (Post 6203670)
Look great...
One more project for the winter if everything go as plan this Saturday (my Winter/Spring/Summer project) :eek::D:eek:
http://forums.pelicanparts.com/uploa...1313711674.jpg
