LM2-tach signal goes flat
I have an LM2 with a working (sort-of) tach signal. The problem is that it starts to cut out and becomes flat. The tach signal comes from an HPX which sends a 5V square wave. That signal goes to my DWUR and the LM2. It is connected to the car's tach through a transistor that isolates the signal and provides enough current to drive the car's tach. The problem has gotten progressively worse. If it were a ground problem, I would expect the other signals to also cut out. Anyone experienced this before?
Here is a picture. http://forums.pelicanparts.com/uploa...1313793686.jpg |
bump
Have you tried their Forum?
I had browsed their forum prior to posting here. This forum usually has a lot more responses. Plus there are a few here with LM 2s so I thought I would try it here first.
I don't know the LM2 very well. I do hear the tack signal can be finicky. Wish I could be of more help
Problem solved! It was not the LM-2 at all. It was the signal generated by the Electromotive HPX. It turns out the ground wire was coming loose. Tightened it up and it got rid of the flat lines.
Cool, I still need to set up my LM2 to read the tach.
Updating this post for posterity.
Seems the ground wasn't the problem, since I continued to get flat readings. I decided to try increasing the voltage from the HPX tach output (5V square wave) to 12V. I did a test today and everything registered well. Signal has much less noise. Also the car tach and the LM-2 register correctly. The voltage was increased using a NPN Tip 31 transistor. The tach input (the HPX signal) went to the base through a 500 ohm resistor, the emitter went to ground and the collector went to 12V, through a 50 ohm resistor. The tach out is from the collector pin. This inverts the signal, but increases the high voltage to 12V. |
Yep, the RPM sensor looks for a +12V square wave or nearly so
| All times are GMT -8. The time now is 11:38 PM. |
