-   -   i need some help with part numbers... (http://forums.pelicanparts.com/porsche-911-technical-forum/62567-i-need-some-help-part-numbers.html)
bell 03-13-2002 05:18 PM
i'm going to order my parts at the end of the week and need to make sure i get the correct pieces. i did search the archives but can't seem to find the info i need. my pcar is an 85'carrera w/3.2.
1.......doing "my" first valve adjust. i need the gasket kit for the valve covers, and anything else related that i'll need. i have already bought the cornwell feeler guage handle and blades.
is this number correct for the gaskets? H-100-907-04 , i didn't realize gaskets would cost that much
2........going to install new NGK's. need the correct part number for the "heat range" of the plug for the best performance, it will be autocrossed and DE'd this summer so i want the best overall performing NGK.
i'm sure i'll have a few more questions..........
and thanks in advance:)
Eric Coffey 03-13-2002 05:59 PM
expensive gaskets?
You should be able to find a complete gasket set, including new nylock nuts, and washers for under $30. Check out the following threads for more DIY valve adjust info:
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=56244
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=60745
Have fun!:D
bell 03-14-2002 06:35 PM
i couldn't find a link in those 2 threads where i can get the parts needed for that wonderfully low price.
can someone either email me or post here where i can aquire them.
thanks again
Eric Coffey 03-14-2002 07:55 PM
Bell-
Check your email.;)
bell 03-14-2002 08:19 PM
thanks for the help
it is GREATLY appreciated SmileWavy
