VEMS install Porsche 911 Carrera 3,2 170kW/231PS motorcode 930-20, help needed
Hi,
i´m planning on installing a VEMS unit on a stock 89 Porsche 911 Carrera 3,2.
From what I read so far I´m quite confident that it should work, although there are no applictions so far ?
However some questions are left. (as it seems i´m the pioneer for the 911)
Let me start with the facts found so far and my plans for application:
- Motor 3,2litre normally aspirated
- trigger system is 2 VR sensors on flywheel / starter ring gear
- rev sensor is sensing 129teeth per crank rev
- TDC sensor is sensing 1 pin on flywheel (don´t know yet how many degrees before TDC)
- no cam or distributor sensor
- stock NTCII at cylinder head #3
- AFM (flap type) will be removed, will use TPS instead (exchanging stock idle and WOT switch)
- idle control valve is the "silver cigar" BOSCH thing, not sure if stepper motor or PWM ?
- IGN distribution will remain untouched in first step, stock coil, stock distributor
- stock fuel injector BOSCH 0-280-150-158 low-Z (2-3 Ohms)
- stock fuel pressure is 2,5bar
- wideband O2-sensor will be used intead of stock narrowband
- no MAP, no airtemp sensor planned
- Firing order for the Carrera is 1-6-2-4-3-5
- wiring should remain mainly stock with stock-DME-connector and only additional wires for wideband, TPS and so on
- planning to use alpha-N only
Now to the open issues:
- first step is to use as much stock as possible, get it running and then in the next step think about wasted-spark, sequential injection,...
- primary trigger: 129 is quite hard to divide, only possible value is 43 ! -> 6 triggers, 120° Will this work ? (AUDI div by n)
- any drawbacks due to the 129 teeth variant, like rev limit or so ?
- secondary trigger is the TDC-mark on flywheel
- what type is the idle control valve ?
- what to do for the low-Z-injectors ? Is there a bolt-in compatible high-Z-variant ? The stock setup is 3 injectors parallel for each bank.
The ones from the 964 are high-z but have lower cc/min @higher pressure
I´m looking forward to get into discussion with you guys.
Is there someone running a VEMS or MS on a 3,2litre ?
Best air-cooled grettings from Germany,
Marcus
Old 08-16-2011, 11:04 AM
Vems
What can I say, install VEMS ECU in 911 you are not pioneer, maybe you are this with your 3,2 liter engine.
Look:
My TPC-d 993 has now VEMS brain, intercooler and more.. - Rennlist Discussion Forums
and this:
Standalone install on stock 1992 964 C2 (dyno graph included) - Rennlist Discussion Forums
They both use only original flywheel triger, no more trigers.
idle control valve is PWM, not stepper.
P 964 C2 1992 with some minor changes
Old 08-16-2011, 11:30 PM
Regarding the trigger wheel of 964 and 993:
They both use the 60-2 wheel which is default for all modern motronics and VEMS and....
Old 08-17-2011, 12:00 PM
no-one else any ideas ?
Old 08-20-2011, 10:53 AM
