911 rear seat removal
I am in the process of removing all the carpeting in my 80 sc to eventually replace it. Everything went well untill I tried to remove the screws that hold the back seats to their hinges. The "screw" has a very long slot and it does not want to give. I do not to screw it up so much that I can not get it out. Any suggestions? Thanks
Old 09-15-2011, 02:32 PM
Dueller's Avatar
I literally did this 15 minutes ago. I ended up having to clamp vice grips on the screw/bolt head to break it from being labor bound. Once it broke free I was able to uncsrew it with flat bladed screwdriver. The seat back then easily pulls off the post it rides on in the center
Jim
1987 Carrera
2002 BMW 525ti
1997 Buell Cyclone cafe project
1998 Buell S1W: "Angriest motorcycle I've ever ridden."
Old 09-15-2011, 02:53 PM
I just did this last week as well. I used a very large flat blade screwdriver that has a 10mm end on the shaft. put a wrench on the shaft to get good torque and it came loose nicely.
87 G-50 Coupe
2001 540 sport Wagon(Wife's)
1996 Volvo 855R (work Machine)
"If it seems simple enough its probably complicated"
Old 09-15-2011, 04:01 PM
Weekend Mechanic
vulcan300's Avatar
Start by banging on the screw head with a hammer, or if you can't get a good shot at the screw head use a long ratchet extension along with the hammer. The impact may help loosen up the thread. The use D'STARGAs method above to break the screw loose. A large pair of vice grips on a large flat bladed screw diver should give you the leverage to break the screw free. Make sure you apply steady even pressure to the screwdriver so that it doesn't slip and strip the slot. Good luck!
J
86 911 Carrera Targa
Old 09-15-2011, 04:50 PM
Wash. State
nesslar's Avatar
Yep. You could also try to 'tighten' it just a touch, then use the big screwdriver (long SD with a wide blde) and then use the wrench on its handle to loosen it. Just be sure to keep the blade of the SD IN the slot while you turn it loose. Don't want to screw up the slot. The key I think is a BIG screwdriver, a long one. With a wrench/pliers on the handle, it should be plenty of leverage.
Old 09-15-2011, 05:04 PM
Mitch Leland's Avatar
After soaking the bolts for a couple of days the bolts still wouldn't come out. I tried big screw drivers with a box wrench w/o success. I finally took a cold chisel to the edge of the bolts and rotated it out. It was ugly, but Pelican Parts has new ones.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 09-15-2011, 07:53 PM
nkotselas's Avatar
I used a crow bar.
Nick
'78 Turbo Look w/ euro 3.2
Old 09-15-2011, 10:03 PM
nineball's Avatar
Sears: Online department store featuring appliances, tools, fitness equipment and more
worked like a charm for mine
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 09-18-2011, 06:32 AM
