How to swap different CV joints?-Yr to Yr
Can I just get my hands on some old style 4 bolts cv axles/and joints--Change the inner and outter flanges from the trans, and trailing arms, and bolt it all up?
If there's a better way to have the bigger bolts WITHOUT changing the transmission...let me know.......... All ideas/comments are very appreciated..s in Va |
It's not always as easy at it appears. The outer axle flange has to have the correct size/splines to fit into the axle stub (which did vary).
| All times are GMT -8. The time now is 09:55 PM. |
