Do I have to drop the engine to replace a bad oli cooler?
Jeff Caron |
If you mean the internal coller, you don't have to drop it but you do have to lower it.
Bring it down about 6 inches and you should be able to reach.
Clark Retired, I'm now posting under my real name Chuck Moreland Day Job - Elephant Racing Basic Transportation - '86 Cab - "Sparky", '77 Targa - "The Peaper" |
junior...naturally use new O-rings/seals. Don't know w/year you have, but my 2.7 has a factory case weak spot under the cooler. I check for any possible case cracks that will leak oil. I simple pressure test may not show a cooler leak. Send it out or do it by the book, IMHO. I changed my cooler by dropping as Clark said.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
