Fuel Pump Ground Wire
Hello. Can any one tell me where the ground for the fuel pump is located? Meaning where the chassi ground is located in the car.
Car: 1980 SC 3.0L thanks
1980 911 SC Coupe 1987 944 Last edited by brett25; 08-26-2011 at 04:25 PM.. |
There is one behind the dash radio area, under the hood in the area where the wiring comes through to the fuse block and I believe there is one under the dash by your left knee.
Bruce |
The fuel pump is grounded at G-3 which is where the battery ground strap locates to the body.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
ok thanks, now im not sure whos right, any third member want to weigh in? There's a rubber chicken in it for the winner
1980 911 SC Coupe 1987 944 |
I looked at the Bentley to confirm my thoughts.
ok thanks crusty!
Maybe it changes by year? I just happened to look at my car the other day ('74 911) and the fuel pump ground is located behind the dash in the area as Bruce mentioned - the one located near the driver's left knee. . .
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
It does change by year. An 84 grounds on the fender just behind the fuse panel.
