-   -   not level in the rear (http://forums.pelicanparts.com/porsche-911-technical-forum/627055-not-level-rear.html)
tadco 08-28-2011 05:36 PM
I am rebuilding a 911T.
I needed to put a new metal tube on the left side rear torsion.
I replaced the outer 300mm of the tube and used 3" OD X .083 wall tube.
I stuck it together knowing it would not be level.
Indeed it was low on the left.
Then I raised the left up one tooth ( I think ) and it is now too high.
At first it was about 50mm low and not it is less than 50mm high.
How much should one tooth raise it?
Do I need to know anything else or just try again until it sits level?
Thanks,
Tony
Flieger 08-28-2011 05:50 PM
The inner torsion bar end has 40 splines. The outer end has 44 splines. You turn the inner end up one spline and the spring plate down 1 spline and you get 0.8 degree increments for adjustment that way.
tadco 08-28-2011 06:18 PM
Being able to move it .8 degrees at a time will make it much easier.
Thanks for the information.
Tony
