Poll: How many miles did you get out of your 911 untill you had to rebuild the motor?
Poll Options
1985RedTarga's Avatar
How many miles untill rebuild?
I was reading a recent post about when most owners opened up the motor to rebuild it, or at least a portion of it. So I thought a poll was in order.
Jamie
Old 08-30-2011, 12:44 PM
emac's Avatar
Jamie
135k and nothing but oil changes plugs etc. Runs like a top
Old 08-30-2011, 12:51 PM
135,000 before rebuild but it ran fine just leaked and consumed a little oil. Runs awesome now and should be good for a long time with brass bushes etc.
69 911e
Old 08-30-2011, 01:56 PM
gtc gtc is offline
abides.
gtc's Avatar
A bit over 300,000 miles here, and nearing rebuild time I think.
Graham
1984 Carrera Targa
Old 08-30-2011, 02:21 PM
I'm at 95k with nothing major. I'm beginning to see some signs of needing a rebuild in the future.
1985 Triple Black Cabriolet-ROW**Sold**
2008 Cayman S Guards Red/Black
2007 Audi A4 2.0T Red/Black
Old 08-30-2011, 02:27 PM
<insert witty title here>
Christien's Avatar
Pulled the 2.4 just shy of 160k km, so around 100k miles. It was running ok, but smoking, and a bit tired. Of course, it's possible there's another 100k km on there, as it's only a 5-digit odometer, but who knows.
I just bought a 154k mile 3.0L to put in there that had excellent compression and leakdown #s, for that mileage. Should go another 100k before requiring a rebuild.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 08-30-2011, 04:26 PM
113K stll runs great and no leaks
1989 Cabriolet
1970 911E Sold
Old 08-30-2011, 04:49 PM
Scott R's Avatar
Dead cylinder at 120k. Turned out to be suffering from a lot of shady wrenching, chain ramp floating around inside of the case, wrong oil used and badly pitted cams. Failed safety collar rattling around in block, bearings down to the copper, RTV all over everything.
So if you figure mine was one of the bigger train wrecks on a 3.0l it did very well all things considered. But it needed a ton of new stuff, p&c's, a cam tower, new cams and rockers. I don't think we reused anything besides the case and the crank.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-30-2011, 05:21 PM
DanielDudley's Avatar
All of the 911s I have owned have had at least top end jobs. None have had under 100,000 on the odometer.
I like to warm them up, but I am not afraid to use them. I wouldn't be very happy driving a car for 300,000 miles if I couldn't drive it. In fact, I have sold a few garage queens because I wouldn't drive them.
Old 08-31-2011, 02:37 AM
Top end rebuilds count, correct....? Yes, top end gone at approx. 68K miles on my 87. Although it really pi**ed me off at the time, I'm over it now b/c my good friend did an excellent job. She runs great and burns/leaks no oil now. It ticked me off so much I bought a 993! Well over 100k on her w/no rebuilds yet... but if it happens, I will be much less pi**ed b/c of the miles on her.
97 993
prior p-cars:
76 912E
85 targa
Old 08-31-2011, 04:40 AM
rootmatt's Avatar
Got to 260000 km (about 160000 m) before it broke a valve spring. While I had it open, I couldn't see any sign of any earlier work by the previous owner(s). Still going strong after that minor hiccup.
1982 911 SC coupe RoW
moss green
SSIs and M&K 2-1 muffler
Old 08-31-2011, 05:53 AM
5String
Mine was at 148,000 miles, which I guess close enough to 150k. It required a complete - and I do mean complete - top-end rebuild only, including studs, thank you very much. The guys at TRE checked the bottom end and found the bearings like new. So that was left alone. But man, it sure runs good now.
Oh, and for what it's worth, there was lots of pitting on rocker-arm faces and cam lobes that had to be repaired. A pox on newer oils!
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 08-31-2011, 07:19 AM
