G50 /03 Codes
Hello,
Can someone help me breakdown the codes on a 964 G50 /03 grearbox please Numbers I have found are as follows: G50 003 1 002767 950.301.102.3R Thanks in advance |
What do you want to know? You already know its a G50.03.. the rest are sequence and part numbers.
Correct. The numbers don't really tell you much
G50.03 transmission version 1 = regular differential (non-limited slip) 002767 = sequential production number In case your curious, gear ratios are 1st = 42:12 = 3.500:1 2nd = 35:17 = 2.059:1 3rd = 38:27 = 1.407:1 4th = 38:35 = 1.086:1 5th = 33:38 = 0.868:1 |
thanks for info guys, we thought this maybe an LSD unit
| All times are GMT -8. The time now is 06:01 AM. |
