hank911's Avatar
Fresh Air blower?
Just got my 76 the other day and the PO had removed this from under the front hood as it was non-op.
Need a new-one, but what's the exact description?
Great news, I have a few months before I'm driving again!
Old Man Winter
HankP
1976S Targa
BMW R100RT&RS&R75/5&6
Horizontally Apposed
Old 12-11-2016, 03:29 PM
85911's Avatar
You are correct- it is the fresh air blower installed at the rear of the front trunk. Before reinstalling, thoroughly check the motor, brushes and bearings, and install a 15 amp fuse to protect the circuit. Then check the other 5 blower motors: 2 footwell for heat, one engine compartment for heat, one evaporator for the A/C, and one condenser for the A/C, and fuse each.
Old P cars are famous for fires from these old (6) blowers.
(I'm referencing an '85 Carerra. I'm assuming your '76 is the same.)
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 12-11-2016, 03:52 PM
Originally Posted by 85911 View Post
(I'm referencing an '85 Carrera. I'm assuming your '76 is the same.)
No footwell blowers in a '76... none until '84.
Good chance he does not have AC either.
Old 12-11-2016, 05:24 PM
hank911's Avatar
Correct on the no AC too.
The bearings seem fine.
New brush's? It's a common thing for me on the stator's of my BMW airheads,alot cheaper than a new motor too!
HankP
1976S Targa
Old 12-11-2016, 06:26 PM
0-130-007-002-M14 is the part number for the motor only.
For an extra $67.50 you can buy it complete with fan. 911-571-320-32-M6.
Just fitted one to my car. Make sure the PO has kept the gasket (rubber sealing ring) that surrounds the assembly.
1978 911SC
Old 12-11-2016, 06:31 PM
