rebuilt engine low compression
I am looking at buying a 75 911 with records indicating a rebuild less than 3K ago. The compression numbers on the engine are all between 135 - 145. If I am not mistaken, should they not be significantly higher? I thought they should be around 160 - 170 range. The pistons, cylinders and everything else where changed and the owner has documents showing all work yet the numbers seem low to me. Should I pass on this or take a chance? Thanks for any help.
How was the test done? Warm, cold, WOT?
cis test kit
I saw where you spoke of a CIS test kit (where are these accessed from ?) I have been thinking of changing from cis to carbs on my 1973.5 911T ,, i have had cold and hot start problems as long as i have owned the car (10 yrs) thanks for your help john young jyporscheboy@aol.com :confused:http://forums.pelicanparts.com/uploa...1314860984.jpg
is it a MM rebuild? wait, it has 3k miles on it, cant be.
how much? |
They are fairly even, which is a good thing. If it was me, I'd do a leakdown test, a fresh engine should be under 2% across the board.
Those tests don't mean a lot except that they are around the same. You can change that number by changing the cam overlap. Do you know where it's set?
Sent from my iPhone using Tapatalk |
75S is only 8,5 compression, you would be in good shape to hit 150#
Bruce |
sorry |
145 to 150 is normal on those. readings will vary a bit between different gauges.
who did the rebuild? MM=motor meister
I have a '75S with the same problem. I rebuilt the engine 10 yrs ago, but it only has about 7000 miles on it. I installed Solex cams and Webers. The cam timing was spot on when I put it together, but Im only getting about 135psi, even across all the cylinders. I didnt do a compression check until a few months ago. I was a little dissapointed, but it runs strong. Measured with engine warm/hot, at WOT. Im not sure if I need to investigate further or not. Also, Im not sure how some people get such high numbers. Shouldnt the theoretical pressure readings be approx 14 psi x Compression Ratio?
I am going to pass on this one and get another. Thanks for all the help guys. Thanks for your information also John. |
I would not buy a recently rebuilt motor unless I knew what shop did the work and what piston an cylinders where used.
If the receipt says new Mahle piston and cylinders I would not hesitate to buy it. I would probably pass on anything else. |
- Cranking speed - Make sure the battery is fully charged and all spark plugs removed. If the newly rebuilt engine is "tight", cranking speed may be lower than normal. - Valve timing - more aggressive cams have more overlap and may require additional compression strokes to register a "normal" reading - Altitude - Higher elevations reduce the compression pressure - Compression ratio - Compression pressures are affected by the compression ratio. What is it? Do not adjust the cam timing to improve the compression pressure. That's counterproductive as well as retarded (as it relates to valve timing), but you know what I mean. Sherwood |
Since an "S" cam gives high end power, at the expence of low end torque, wouldn't you expect low speed compression checks to come out on the low end of the spectrum??
| All times are GMT -8. The time now is 08:05 PM. |
