-   -   77 Carrera 3.0 C3 Engine Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/627861-77-carrera-3-0-c3-engine-questions.html)
dporsche74 09-02-2011 05:01 PM
HI
I just saved a 77 3.0 Carrera # 235 barn find
it has the vin 91176xxxxx
667xxx 930/02 engine
paint code 264-9-3
, it has around 90K miles and needs engine rebuild
Should I rebuild has stock or it there a semi easy mod for this engine
Looks like the 76-77 3.0 are 200HP
and in the spec book 78-83 3.0 have the same heads ,pistons , cylinders 180HP
are the cams differnt in the C3
Any advise would greatly be appreciated
http://forums.pelicanparts.com/uploa...1315007962.jpg
http://forums.pelicanparts.com/uploa...1315008060.jpg
Tom F2 09-02-2011 05:28 PM
Why does it need an engine rebuild? That's low mileage on a 3.0 engine.
dporsche74 09-02-2011 05:37 PM
Looks to me the oil is leaking out of a cracked cylinder
Tom F2 09-02-2011 05:41 PM
Does the engine run?
Flat6pac 09-02-2011 06:56 PM
Everything is the same, even the cams but you couldnt have the 2.7S at 175 and the 3.0 at 180 now could you?
Bruce
jsveb 09-02-2011 07:27 PM
The crank is different on the Carrera 3.0 vs the sc
I think the cam timing is also different. The Carrera 3.0 is a bit more old school tempered, really comes alive at around 3800 rpm. the sc is a bit more linear. Drove mine for about six years stock - loved it.
Awesome car. Congrats
soren.911 09-03-2011 12:38 AM
The crank is the same as the carrera RS. That is why the carrera 3.o engine popular for historic race engines.
Tom F2 09-03-2011 04:41 AM
Interesting, color code 264=viper green diamond metallic, a color that I've never seen. Is this the color that is on this car?
Looks great, regardless!
I suggest that you leave the engine stock, and just backdate to the SSI style exhaust. The large port 3.0 engines seem to benefit the most from the SSI's.
Any large port, no a/c 3.0 liter, whether SC or Carrera 3.0 is a great car. Personally, I think that there is no difference between the Carrera 3.0 motor and the 8.5 C.R. SC motor. That's just my seat of the pants impression, from driving a few. I owned a 79 SC, which was nice. The 83 RoW car, with 9.8 C.R. feels significantly quicker, especially with the SSIs.
A cracked cylinder sounds like a Turbo problem, not something that you see everyday on a normally aspirated 911.
dporsche74 09-03-2011 05:55 AM
264 is emerald green metallic, special order color in red book
someone gave it a full paint job in the 90's to Black
its a total bummer,
I am really on the hunt for a good painter to in New England Connecticut ,
,this C3 needs needs to be 264 once again
Bill Verburg 09-03-2011 06:39 AM
The bottom end, ie crank rods, flywheel of a C3 is the same as that of a 2.7. The block is the later aluminum version rather than the magnesium used in 2.7s, the distributor and ignition are also pure 2.7
The top end ie pistons, heads, valves, cams, injection is the same as was later used on 3.0 SCs, exhaust was also the same as SCs except a pre-muffler instead of a cat
the extra hp over the early SCs comes from tuning the ignition & fuel and cam timing
SSI's are a nice addition for these engines as is a 98mm higher compression p/c set
dporsche74 09-03-2011 06:50 AM
thanks for th einfo
so would the 98mm p/c set just be bold on upgrade
would i have to cut/change the heads for the larger size p/c
I want to upgrade but not change the engine so it cannot be turned back in the future maybe
thanks
Bill Verburg 09-03-2011 07:23 AM
Originally Posted by dporsche74 (Post 6233846)
thanks for th einfo
thanks
I suppose it depends on the p/c set, for the cis, 9.8cr, 98mm p/c sets from Mahle the heads do need a slight chamfer
Tom F2 09-03-2011 08:56 AM
Sent you a pm.
