nilknarf's Avatar
email on the way!
Curt
66 912 ... 2.7 conversion (What a blast!)
79 928 5-spd (sadly, sold)
85.5 944 5-spd (sadly, traded for 928)
www.curtfranklincreative.com
Old 06-19-2012, 11:40 AM
Another email on the way!
Gary
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 06-19-2012, 12:54 PM
Guys, Bob is a great guy to work with, key word being with. Anyone doing business with him should have a great experience. I highly recommend him!
gary
Old 06-20-2012, 01:46 PM
As expressed in my post above, Bob is a great guy to do business with. Well, I just installed his tach adapter in my 70 to make a 75 tach work and all problems solved. Great guy, great product. Been thrashing around with the problem and now it is solved for not many $$. I am a happy camper. Thanks Bob.
gary
Old 06-26-2012, 02:21 PM
nilknarf's Avatar
I haven't installed mine yet, but I agree- Bob has been a very good communicator!
Curt
Old 06-26-2012, 02:27 PM
I was really stuck with the MSD box on a 70T. Tried the MSD tach solution and no go. Talked to MSD , that didn't work. I contacted Bob and after reading the positive reviews and decided to try his product. After spending 5 hours on the MSD unit it took us 30 minutes with Bob's Tach Adaptor to get the tach to work again. His communication with myself and my mechanic really made it happen. He responds super fast and explains what you are trying to do. I wish I went with this from the start. If you have tach issues Bob is your man!
Old 09-07-2012, 02:14 PM
77 TARGA WIDEBODY
Damn, I bought the dakota digital one, It did not work for my application, I sent my tach out to hollywood speedometer, it works well now but 4 times the cost. Where were you a few months ago!
Good luck with it!
Old 09-07-2012, 07:28 PM
Thanks for all the positive feedback. It's nice to see this little product working out well for everybody. For more info, check my TACH-ADAPT site home page Home
Old 09-08-2012, 11:48 AM
Thanks Bob.
The original tach (green faced) in my -66 is alive and reinstalled. The 3 pin CDI on the high comp 2.2 MFI did not trigger the tach so Ive been using a 72 making the dash look odd.
This well engineered and easy to install (and cheap 77usd to europe) really made it.
-Bo
Old 09-30-2012, 06:02 AM
I don't post too often but I scan the pelican boards every day. I more often than not find answers to my questions and solutions to problems. On two recent occasions Bob Ashlock, a fellow pelican, has come to my rescue. Most recently checking and repairing some old 3 pin bosch CD units that I and a friend needed. I can't say enough good things about Bob. Called me twice to discuss the work. Not only did the work get done well and quickly, but the price was very reasonable. About $100 to get a 3 or 6 pin CD working again. And his tach adapter works like a charm. All you guys with early CD ignition probs just contact Bob Ashlock at his email ratech@pacbell.net. He is really one of the good guys.
gary
Old 11-18-2012, 06:43 AM
Ho Bob
I have a 1971 911T which I changed to MSD6AL
The original electronic ignition was missing when I bought the car - and I temporarily ran points and condensor just to get the car up and running
With this setup the Tach worked although it was quite bouncy
Post installation of the MSD , the Tach now does not work - hence my trawl through the 911 DIY holy grail
I have the old Tach (with a 1 on the connector ) (pic attached )
but it has a green wire ?
I have tried connecting this to the MSD grey Tach wire but nothing happens.
Will your TachAdapt work for this application ?
Cheers Kenny
Old 02-04-2013, 10:06 AM
Hi Kenny,
YES, this is a typical application for Tach-Adapt. It will take the low-level 12V tach signal from the MSD and convert it to an output that will be suitable to make your vintage tachometer display correctly.
If you need more details, you can communicate direct with me at Bob@AshlockTech.com or you can view my site Home to learn more about the product and order it on-line.
Thanks much for your interest - Bob
Old 02-04-2013, 10:17 AM
Just a quick update... the TACH-ADAPT product is now also available from our host. Just enter part number PEL-TA-V3. For technical details you can also visit my site: www.AshlockTech.com
Old 07-14-2013, 04:36 PM
zed zed is offline
electronspeed
Thought I would chime in. As of this time I think I have used 10 "yes ten" of these units
in every weird mix and match 911 combination possible.
This "IS" the solution "Period"
Thanks Bob // Steve in Alt.
Old 07-25-2013, 08:41 PM
Bob, are you still servicing CD ignition units? Mine died two years ago and using my spare now... would like to get my dead one working to keep as a spare! It's a 3 pin Bosch. What do I need to do to get it over to ya?
Thanks!
Old 08-25-2013, 04:44 PM
Hi, yes I service the CDI units routinely. On my website home page towards the bottom there is a brief explanation of this service. Check Home
You can ship the unit to:
Bob Ashlock
1218 N. Lemon St.
Fullerton, CA. 92831
Old 08-25-2013, 05:25 PM
Administrator
Pelican Parts offers CD box repair! Give us a call at 888.280.7799 7am - 5pm PST and we'll take care of your repair needs.
Mark/Pelican Parts
Old 09-05-2013, 02:48 PM
Bob, Thank you for such a simple solution to a common problem! In my case, I am running a set of 914 gauges in a Karmann Ghia with a big CC VW type 1 motor and MSD ignition. This is just what I need! Bob was very helpful and quick to respond. Highly recommended!!!
Old 12-15-2014, 05:11 PM
would the TACH-ADAPT work on motorcycle that has a 4 cylinder tach and engine has been changed to to 6 cylinder?? My tack is for a 4 cylinder and now have 6 cylinder engine
thanks for any info .
diver
Old 02-09-2016, 07:54 AM
Generally this works for most motorcycle applications. Thanks.
Old 02-09-2016, 02:11 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
