El_Mecanico's Avatar
Engine smokes at idle
I purchased sw chip and very pleased with the performance however I did notice the engine exhaust smoked a little bit after the chip replacement. Now when I turn on the air-conditioner she will smoke you out of the garage especially after charging the system. What are your thoughts. Could the additional load of the compressor cause excessive smoke at idle? Its seems to be oil burning...not black smoke that I can tell or its time for a top end job?
1986 Porsche Carrera
1997 Porsche Boxster (Sold) :0
1995 911 Cabriolet (Sold)
1971 Porsche Targa 911E (Sold)
Old 09-03-2011, 05:37 PM
Mo money = mo parts
"Could the additional load of the compressor cause excessive smoke at idle?"
No.
"Its seems to be oil burning...not black smoke that I can tell or its time for a top end job?
Sounds suspicious. Is it using oil? Meaning...how many miles can you drive before you need to add a quart of oil?
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 09-03-2011, 05:48 PM
abit off center
cgarr's Avatar
Did you remove the cat?
______________________
Craig
G2Performance
Old 09-03-2011, 06:06 PM
Yes, I removed the cat and noticed an awful smell soon after...my friends would comment about the smell when following me. The engine doesn't smoke under acceleration ,just at idle...valve guides I suspect.
Old 09-04-2011, 02:53 AM
Originally Posted by El_Mecanico View Post
I purchased sw chip and ...not black smoke that I can tell or its time for a top end job?
Did the old chip make you think of a top end job too? Maybe putting the stock chip back on might solve your smelly smoke problem.
Old 09-04-2011, 03:08 AM
abit off center
cgarr's Avatar
The cat was masking the oil burn smoke, mine did the same thing, come to a stop and she would belch smoke... it was not the chip but removing the cat that let the smoke show its self. Most likely valve guides.
Craig
G2Performance
Old 09-04-2011, 03:55 AM
I'm thinking the same thing...I'm looking into replacing the cams with the 964...Is there a noticeable change in idle and performance? I might as well change it since I'm in the engine.
Old 09-04-2011, 07:57 AM
