-   -   Possibility of R& R of rubber coupler at #5 intake runner (http://forums.pelicanparts.com/porsche-911-technical-forum/628140-possibility-r-r-rubber-coupler-5-intake-runner.html)
mspirito 09-04-2011 06:41 PM
I have determined that the rubber coupler at #5 is cracked. I am not too keen on replacing all of the other couplers now just want to keep it on the road til the cold hits.
Is it possible to remove and replace this coupler leaving everything else in place?
Do I need to un-do the injector if so? Any help is greatly appreciated
Bobboloo 09-04-2011 06:51 PM
1. Loosen the boot clamps.
2. Remove the injector. (not necessary but maybe easier)
3. Unbolt the intake runner for #5 and anything else attached to it. (Aux air valve?)
4. Lift the intake runner up and out.
5. Replace boot.
You can also undo the support for the airbox on the right side if necessary.
mspirito 09-04-2011 06:53 PM
Thanks , to remove the injector do I just unscrew it?
Bobboloo 09-07-2011 07:15 AM
It pulls out. It has an O-ring that holds it in place. Sometimes they are hard to pull out. You might just leave it in and remove the runner. There should be enough slack on the injector line.
Scott R 09-07-2011 07:50 AM
Don't leave the injector in, you can bend it removing the runner in this manner.
manbridge 74 09-07-2011 10:11 AM
I believe OP is working on a 74?
About a month ago I removed runners on my base model 74 without removing injectors first. I don't recall any injectors trying to hang up/bend.
Perhaps an S model or those with larger runners would be where injectors might bend?
