-   -   Electrical guru's--Need help-Window Relay (http://forums.pelicanparts.com/porsche-911-technical-forum/628292-electrical-gurus-need-help-window-relay.html)
ben parrish 09-05-2011 02:38 PM
My windows and sunroof stopped working...traced it down to the relay. I pulled the relay and took it apart. I can put a spacer between a contact(picture 1 and 2), causing another contact to make contact and the windows will work. My belief is that there is a capacitor(picture 4) that has gone bad becaue it gets very warm when the relay is energied....reardless of the spacer...but I am really out of my element. Pic 3 is the schematic.
http://forums.pelicanparts.com/uploa...1315258101.jpg
http://forums.pelicanparts.com/uploa...1315258154.jpg
http://forums.pelicanparts.com/uploa...1315258291.jpg
http://forums.pelicanparts.com/uploa...1315258386.jpg
86 911 Targa 09-05-2011 02:59 PM
Here are a few more pics.
Indeed, capacitors are the "usual" suspects in a failed circuit such as this one.
Although, the relay may have dirty contacts, or is not closing
due to a cold solder joint.
pm me as needed.
Gerry
http://forums.pelicanparts.com/uploa...1315259782.jpg
http://forums.pelicanparts.com/uploa...1315259814.jpg
dad911 09-05-2011 03:53 PM
Relays are simple to test... put 12 volts across the windings, and it should close. Measure resistance across closed contact, it should be nearly 0.
lucittm 09-05-2011 06:07 PM
The role of the capacitor, C1, in this circuit is to quickly charge, in about 1/2 second, when the ignition is turned on. The charged capacitor keeps the relay de-energized. After the capacitor charges, no current flows through it from pin 85 to pin 86 until the door switches are closed which provides a path for the capacitor to discharge and the relay will latch to power the window motors.
The diode, D2, prevents a reverse voltage spike, the inductive kick, when the coil de-energizes and allows the voltage to flow back to ground. The combination of R1 and D4 act as a snubber circuit to prevent arcing across the relay contacts.
dad911, in the post above, describes a relay test but this will not test the function of the shunt capacitor, C1, or the snubber circuits.
Reflow the solder joints on the back of the circuit board and you may solve the problem.
Mark
Rot 911 09-05-2011 06:16 PM
Where is that relay located? I was trying to trouble shoot this a couple of weeks ago and couldn't find it on my '86.
crustychief 09-05-2011 06:38 PM
It is behind the oil temp / pressure gauge.
86 911 Targa 09-05-2011 07:02 PM
Originally Posted by lucittm (Post 6237985)
the role of the capacitor, c1, in this circuit is to quickly charge, in about 1/2 second, when the ignition is turned on. The charged capacitor keeps the relay de-energized. After the capacitor charges, no current flows through it from pin 85 to pin 86 until the door switches are closed which provides a path for the capacitor to discharge and the relay will latch to power the window motors.
The diode, d2, prevents a reverse voltage spike, the inductive kick, when the coil de-energizes and allows the voltage to flow back to ground. The combination of r1 and d4 act as a snubber circuit to prevent arcing across the relay contacts.
Dad911, in the post above, describes a relay test but this will not test the function of the shunt capacitor, c1, or the snubber circuits.
Mark
+1
Lorenfb 09-05-2011 09:47 PM
"The role of the capacitor, C1, in this circuit is to quickly charge, in about 1/2 second, when the ignition is turned on."
Since the diagram is totally wrong, the above analysis is also totally wrong,
First, the circuit is a delay timer run off the 'X' pin of the ignition switch
to power the windows after the ignition switch is turned off. Pin 85 goes
to the 'X' terminal of the ignition switch. Second, this relay has a transistor
not shown on the posted erroneous wiring diagram (but on the opened relay
picture), which most likely comprises the delay function with the capacitor.
Bottom line: Before analyzing what could be the problem with the relay,
let's try and post the correct diagram!
