-   -   '72 911 - Front End Height Adjustment (http://forums.pelicanparts.com/porsche-911-technical-forum/628316-72-911-front-end-height-adjustment.html)
Dean DS 09-05-2011 04:10 PM
When looking at my '72 911 the right side, drivers side is about 1" lower than the left side. What do I need to adjust so I can correct the height difference? All help is appreciated. I am new at this!
Dean
Oh Haha 09-05-2011 04:45 PM
There are screw-in adjusters to raise/lower the front. My concern would be WHY is the DS so much lower? If anything, it should be a bit higher if the car has been corner balanced and aligned.
You can raise the DS using the screw but you will most likely mess up the handling as you will now affect the PS rear.
What are the rear side to side measurements?
haycait911 09-05-2011 06:28 PM
you'll also need an alignment after messing with the height. best do the complete car and corner balance if you wish. then get it aligned.
