Momo collector
newly fully restored 911 - now dead
Hey Pelicans, looking for some ideas what to check, what problem my car could have. Running out of ideas myself.
Thats the situation: Fully restored 911 from 1977 - everything is new, really, anything. Have put the car together, cranked, and it started at the first attempt. Everything was working. Disconnected the battery. Next time, about 4 weeks later I had to change the steering column bearings (somehow forgot to do this while the car was apart - don't ask why - no answer).
Then I started to start the car again - connected the battery - nothing. I couldnt believe it. Measured the voltage, battery is brand new, everything is alright. Then checked really everything, nothing worked but two things: the hazard and the clock. Nothing else, no lights on the gauges, no pump, no starter - really nothing but the hazard lights and the clock.
Any idea what to check? I am really running out of ideas. I am not a genius when it comes to electrics - I've just put together all the new parts and it worked just fine. Any suggestions are appreciated.
Thanks guys!
Mads from https://www.patipatina.com
Old 04-22-2023, 12:06 PM
Grounds? Plugs thru the cowl from the ignition switch?
206 637 4071
Old 04-22-2023, 12:13 PM
PCA Member since 1988
Since you just took apart the steering column, you almost certainly disturbed or disconnected something in that process.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-22-2023, 12:21 PM
proporsche's Avatar
as John said ..look under the dash -left side , there are 3 plugs -possibly disconnected the one from the ignition switch
Ivan
1985 911 with original 501 761 miles...807 506 km
Old 04-22-2023, 12:32 PM
Check the plug going to the ignition switch first. I've seen that one fall off before.
Old 04-22-2023, 12:34 PM
Momo collector
First of all, thank you all for your replies. Checked the three plugs behind the ignition switch and guess what - two of the three fell out. You guys are geniuses! Thank you so much!
Old 04-24-2023, 05:55 AM
