-   -   Electrical issue with fog lights (http://forums.pelicanparts.com/porsche-911-technical-forum/628472-electrical-issue-fog-lights.html)
82 sportsc 09-06-2011 03:26 PM
fOG LIGHTS/SWITCH WORKED FINE JUST 2 WEEKS AGO.
NOW THEY ARE NOT...I HAVE CHECKED WITH METER AND HAVE NO
POWER EITHER SIDE OF FUSE #1 [FOG LIGHTS].
THE PULL SWITCH ON DASH ALSO DOES NOT LIGHT.
I CONSIDERED REMOVING ALL THE FRONT TRUNK EQUIPMENT
VENTS ,MOTOR ETC.TO GET ACCESS TO BACK OF SWITCH BUT THOUGHT TO CHECK HERE IF BETTER APPROACH.
THANKS FOR ASSISTANCE
FRANK
86 911 Targa 09-06-2011 03:29 PM
FRANK
Good idea, as there are many P-members here to lend a hand.
Do you have a Bentley for your M/Y?
pm me as needed.
Gerry
Canada Kev 09-06-2011 04:28 PM
Also check this thread from today re: headlights. Possibly the same issue if his is the headlight switch or maybe not. Can't hurt to check and far easier than yanking all the stuff in the frunk behind the dash.
Don't know the year of your car, but the fogs are usually a thick grey wire.
http://forums.pelicanparts.com/porsche-911-technical-forum/628445-headlights-stopped-working.html
crustychief 09-06-2011 04:40 PM
Don't forget to check the relay.
Bob Kontak 09-06-2011 05:18 PM
Here is a diagram for the 82 Fog Light circuit.
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_fog.jpg
82 sportsc 09-07-2011 09:49 AM
Foglights
Guys
Thanks a lot for input ,will not get to until this weekend
will debrief on progress
Regards
Frank
