Student of the obvious
Found in engine bay... what is it?
After using my magnet-on-a-stick to fish out the hex wrench I dropped, I ran it around the engine bay to see what else it would find.
Any ideas what this is? It's 1/2" across and 5/16" tall. The middle seems to be a hard rubber or nylon and there's a split ring around the middle. |
PRO Motorsports
That's the hyphenator- happagenator valve for an '83 Buick Regal. It supplies oil to the muffler bearings.
Seriously though, it looks a bit like the snout attachment of a harmonic balancer puller/steering wheel puller.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Recently Disbanded
its a burning ring of fire, thats been extinguished
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
We're a big help ...............
I'm going to guess it's a fuel injector seal. I have 8 of them in a "junk" drawer from a 924, 15 years ago. But they aren't metal, they're fiber. Wait for Mr. Walker to give us the real answer.
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor Last edited by cary; 03-15-2002 at 12:48 PM.. |
i'm still thinking. an injector seal for a 73-74 cis looks a lot like that, but longer. is that an o ring in the notch?
if it were aluminum, it looks a lot like the CO adjuster block-off plug for a carrera air flow meter, with that metal circlip, but they had no step. what year is the car?
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 03-15-2002 at 12:00 PM.. |
It's an '84.
That is a muffler bearing, duh!
Senior Member
It looks like a short tube-type thingie with a black band around the middle. You guys are so slow!
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Well, If your car has mfi on it that piece of rubber is a cap that fits on the back of your mfi pump. It covers the little port that you can manually move the pump rack with. I only remember as I just cleaned out my pump a few hundred miles ago.
If you don't have mfi, I suppose it is a titanium kryptonite cookie! Dennis H. 72 911E |
Lee, other than what it is, I think it's more important to know what it's worth?
"Off a Porsche 911 did you say!" It's probably worth a small fortune on ebay. |
Be careful not to lose it!
I can say with some certainty that the object is a "teddy bear's ars@~ole", well maybe a replacement module.
01 Maserati 3200 GT Assetto Corsa 84 3.2 cabrio - gleaming 99 Alfa Romeo 166 3.0 V6 super - still going 03 Fiat Punto 1.2 http://www.pelicanparts.com/gallery/rob911 |
this is the thingie on the back side of the water pump. Come on guys, muffler bearings don't have a split ring
Looks like a Johnson rod sleeve to me. Make sure it is properly lubricated with Mobil 1 before putting it back on.
Tom '97 Turbo '89 Targa '04 Audi S4 Cab '03 BMW 1150RT |
Information Junky
"teddy bear's ars@~ole", . .?
"Looks like a Johnson rod sleeve to me. ". . .? Guys, TMI! (TMI ->Too Much Information)
