What are the rear trailing arms made of in my car. At the moment they look a sorry sight, covered in all sorts of crud. I'm wondering if they'll clean up very well.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
I believe they're an "alumineeum" alloy as they say in Dingwell (SP?). Jim
They clean up great. Go to kragen or wherever and buy castrol super clean. It's in a spray bottle and works fantastic. I think it's much better then gunk products
72 911 Although it is done at the moment, it will never be finished. |
That would be Dingwall! Jim
Excellent! This will be another step on the road to SC perfection!
Jim, I think you should now be known as groundskeeper Willie!
My hair is a little red but I still have lots of it. Time to stop wasting time and go home and finish pulling the flywheel on my 2.7; had to stop last night as the 12mm triple square bit was twisting (Snap-On even)
and there was no more to grind off. Found a new one at local auto parts store - hard to believe!. Cheers, Jim
Bloody right. ALUMINIUM.
Toblu is on a winner - that Castrol super clean is strong boogie. It was the only thing that would cut the accumulated gunk in my empty engine bay, and works great for parts. Don't breathe it - in fact, dont use it indoors - nasty aromatics will rip your throat out. Found it at that well known purveyor of fine chemistry - Trak Auto.
Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site |
My personal favorite cleaner is good ol' brake cleaner. Just about any veriaty will do. Spray it on and it cuts through gunk like there is no tomorrow -- and it dries off residual free. For tough areas, use a little wire brush while it is still wet. Just be sure to put a pan or something under the work area since a lot of gunk will run off. Also -- and this is important -- have a well ventilated work area since the stuff evaporates real fast and most likely kills brain cells, future children and everything else except for the 3rd arm that you'll sprout after sniffing too much.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 03-15-2002 at 07:34 AM.. |
Hmm. I must be calling another part the trailing arm as the part I mean seems to be made of steel (after much scrubbing). There is an aluminium part attached (circled). The part I mean is the one with the arrow. Time to change from motorbike lingo!
PRO Motorsports
That's the spring plate, and it is steel. The aluminum one is the semi-trailing arm.
That spring plate looks pretty rusty. Good luck with your project!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
thanks Tyson.
Banned
That spring plate was originally cadmium(sp?) plated, sort of gold-colored. Someone must have "cleaned" off the coating, unless it was just the weather over there that did it. For anyone who still has the plating on theirs, you are pretty limited w/ cleaning solutions that won't strip plating and make it just a piece of rusty steel.
