Overrevving and cutoff
My cruise control cable got dislodged and caused my car to get stuck at wide open throttle. It revved, then cut off, then revved ... etc... about 6 times, at which I turned off the ignition. I was stuck in the middle of the road, so I turned it back on and peeled out into a side street, probably 3 more overrevvs. I fixed the cable, which I will probably be cutting off, shortly, as the cruise does not work anyway. There was a lot of burnt rubber smell, but I don't think it is all from my tires. Maybe the clutch?
Question is what is my damage? Car drove fine after I relieved the cruise cable. Thanks, Doug
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo Last edited by na2ub; 09-09-2011 at 11:45 AM.. |
RETIRED
You're probably OK but a leak down and/or compression test would give an indication of engine condition.
Good thing is, the engine was up to temp before this happened. If it was cold, I would be really worried. How do I disconnect the cruise cable without cutting it?
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
Your engine will be fine, you can't really hurt it that way. You must rev it past the revlimit, like missshift.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Happened to me once,..scared the sheeit out of me,....I can assure you that it only took ONE out of control situation before I hit the ignition,..I couldn't imagine 6 or more of these events! All bow to the damned rev limiter to save yo' arse.....
I've often wondered: ( experts will chime)....Why is it that the rev limiter catches RPMs headed "upwards".....but (apparently) doesn't limit revs in a "missed shift" (or "downshift") condition? Why is this? BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Why this is, is because on a downshift over-rev the rear wheels are turning the engine instead of the engine turning the rear wheels. There is no rev-limiter on the rear wheels.
-Andy
72 Carrera RS replica, Spec 911 racer |
I believe the term for this is "mechanical over-rev". Mechanical, meaning it's the mechanical motion of the engine, without the ignition. The rev limiter is doing what it is supposed to do either cutting ignition, fuel, or both, but this doesn't keep the engine from mechanically moving.
Dustin |
1988 Carrera Targa, Guard's Red 1959 356A - long gone 1960 356B - long gone 1978 SC Targa, GP White - Accident - Totaled 2006 (T-boned by a nut on drugs) 2003 VW V6 Passat Wagon |
Best! Doyle
