I just use a long bar with a handle shoved into my lug bolts to hold the wheel while she is on the lift, works great.
Ed, your process involves a lift, correct? I'm asking because I have my engine out currently, but my car on the ground (put the wheels back on). I had it up on jack stands, then lowered the engine out like I always do, but I didn't have one of the jack stands in properly and the car started to lean really badly (scary as hell, first time in hundreds of times lifting the car that's ever happened). I jammed some temporary jack wherever I could, slapped the wheels back on and lowered the car down. Problem is, now I have no idea how I'm going to get the car back up :)
I don't understand why you can't raise your car back up? |
I usually lift the rear of the car by the engine, under the sump plate. That's the way I've always done it, and I'm not sure where else to lift from, if the engine's out.
You should have spots on each side for jack pads.
[QUOTE=efhughes3;6248984]Not sure if it is the "right tool" in as much as it is "a tool". In my mind, the adapter on a floor jack takes a big back seat to using the ATV jack. The ATV jack is a lot more stable.
When "the Tool" arrives I will assess. If I feel the need I will fab something to make it work with the ATV/MC lift and have the best of both worlds. Stability and the ability to adjust the angle of the powertrain without shimming with wood blocks or other dangerous for pinch point methods. I've managed to work on 500KV electrical for 25 years without an injury. I'd hate to have something like a motor drop on me! :D |
Well, I did two drops in 2 weeks. ( don't ask :-( )
I purchased a 1500 lb Motorcycle Jack at HF, with a piece of 1"X12"X36". I dropped both Trans & Engine. I raised her on to 6 Ton Jack Stands until wheels were off the ground. Then placed the Motorcycle Jack with piece of Wood under the center point of the Engine and Trans, about a foot where I normally raise the car. Raised the engine until the engine mounts came up about an inch. Disconnected/Removed as Bentley/101 described. After initial separation, I raised the chassis at the wheels ( engage E Brake ) one side at a time, gradually for safety, until high enough for my heater blower to clear my rear valance. Grabbed the engine mount cross member and polled back, Voila, Engine Out :D INSTALL, I lowered the chassis to the engine, raised the engine about 6"s+/- and slipped right in. All this by myself, took her for a spin today, could not take the silly grin off my face. NOTE: Keep organized, use shoes boxes to keep thing in order or use sandwich bags. The first time I did not do this and kicked my pile of nuts/bolts, What a nightmare :eek: Jim PM me if you have any questions. As far as the CV bolts, I removed the wheel and used a piece of 1.5"X 48" OD wooden dowl and jammed it on the wheel studs. Used the same dowl to rotate as I loosened each bolt. Just make sure the allen tool is seated all the way in before wrenching on it, YOU DO NOT WANT strip it. It is easier to loosen from the top or side position, there is zero room trying to get to the bolts when they are in the lower (6 o'clock position ) I was lucky I only stripped on on 2nd install. I ordered 6 back ups and CV gaskets from our Host. If a pre 85.5 915 it is only 30 ft lb torque. Like you wheels, torque in a Star Fashion. Hope this helps! |
Picking up a 20" long 3/8" extension bar from Sears on the way home from work for the CV bolts. And also borrowing the special Pelican oil line wrench from a fellow Pelican who lives close by. I'll hopefully have the engine out soon. |
This is what my car looked like when I dropped my engine. I did have a little bit of a clearance problem. It worked out as soon as I removed the valence.
http://forums.pelicanparts.com/uploa...1209141877.jpg |
This is what my car looked like when I dropped my engine. I did have a little bit of a problem.
http://forums.pelicanparts.com/uploa...1315865750.jpg |
Anything else that goes wrong with your car seems minimal compared to this-dang! Hope no buddy was hurt.
that was just a joke - also an admonition to be careful ---> note the too small fire extinguisher
Nobody has mentioned removing the bumper. A few nuts and some electrical connections and the whole thing is off. Gives you many much-wanted inches of clearance. Here's my drop with nothing lifting the front, jack stands and wood lifting the rear torsion bar to about 25 inches. ATV jack lowering the engine.
http://forums.pelicanparts.com/uploa...1315870602.jpg http://forums.pelicanparts.com/uploa...1315870622.jpg |
Just realized you already have your bumper off. Good luck with the drop and be careful.
| All times are GMT -8. The time now is 02:33 PM. |
