-   -   quick release hub setup (http://forums.pelicanparts.com/porsche-911-technical-forum/629176-quick-release-hub-setup.html)
hesaputz 09-20-2011 10:35 PM
Confirmation of what? The 20mm size is correct for all 911 air cooled.
scott.k 09-21-2011 03:43 PM
Yes, that is what I was looking for.
Thanks for the help
Scott
scott.k 09-21-2011 03:55 PM
I am thinking of using a vw bug hub adapter, but im not exactly sure what years use the 20mm 40 spline on the bugs. I think its the 60's that use this size, and the later years use 21mm 40 spline.
The reason for this is that they make aftermarket short hubs for beetles, and I would like to use a shorter hub for with the quick release and a somewhat deep wheel, I wont have the steering wheel too close.
I will have to make an adapter plate that makes the hub fit to the 6 hole quick release, but that should be fairly easy
