-   -   Foam behind rear shock tower replacement source? (http://forums.pelicanparts.com/porsche-911-technical-forum/629209-foam-behind-rear-shock-tower-replacement-source.html)
Brown747 09-11-2011 05:52 AM
Doing a cleanup in the back while the engine is out. The foam seal that fills the void between the shock towers and the firewall is all deteriorated. What is being used these days and a source please.
Thanks, Thor
http://forums.pelicanparts.com/uploa...1315745370.jpg
http://forums.pelicanparts.com/uploa...1315745414.jpg
rwest 09-11-2011 07:17 AM
Thor,
Pelican sells it: they call it "engine compartment sound mat" there is a few different types, just do a search on the parts section.
-Rutager
Bob Kontak 09-11-2011 08:20 AM
Nah - not what he is looking for. He needs the foam brick wedged way down there.
I'll find it - Gimme a few.
Bob Kontak 09-11-2011 08:32 AM
Parts PDF calls it a "Strap"
Here is the same part number that PP sells.
Pelican Parts - Product Information: 911-504-930-00-OEM
Jerome74911S 09-11-2011 08:33 AM
Maybe our host sells it, but I used something else. I bought a dense, black foam rubber pad that is made for the reduction of noise and vibration caused by window-mounted air conditioners. The air conditioner sits on top of this one-inch thick material, which can be purchased in any hardware store.
I figured that the idea of the original material in the car was to cut air intrusion and to reduce noise, so the identical looking rubber slab I bought should do the job, too.
Just cut the pad to fit, using two layers as necessary. Mine has stayed in place perfectly with just a friction fit.
Brown747 09-11-2011 09:41 AM
Thanks for the answers! Thor
Bob Kontak 09-11-2011 10:06 AM
If it is not gonna be concours - I like Jeromes idea.
schumicat 09-12-2011 11:40 AM
are 2 different things being discussed here? don't the blocks shown on the PP link install from under the car? and the OP posted photos which seem to be something that goes in the engine bay (like below the engine pad?) In previous threads I read the purpose of the blocks was to block heat.
Brown747 09-12-2011 12:44 PM
The picture is what the blocks in the link look like after 33 years. Pelican Parts - Product Information: 911-504-930-00-OEM
stevie 77 930 09-12-2011 12:47 PM
As discussed the foam pad in the engine compartment and the foam blocks are different. The blocks are installed from underneath the car. The factory "straps" have an addhesive strip 0n one side that faces the shock cross member. The engine capartment pad is glued in and fits in the same cavity, just from above.
I replaced my engine pad and foam "straps" when i had the motor our for a rebuild. I ordered the foam blocks from Pelican.
http://forums.pelicanparts.com/uploa...1315856572.jpg
schumicat 09-12-2011 01:07 PM
Thor, I guess what is confusing me is that you posted photos of the engine bay, which I took to mean that's where you found the disintegrated foam. The blocks install from underneath the car, not in the engine bay. Stevie, that is a clean engine bay.
Bob Kontak 09-12-2011 05:00 PM
The engine bay is where Thor found the disintegrated foam. Those are the straps/bricks. They can be accessed("touched") from the engine bay. Reach into a back corner and you can get to yours.
DRACO A5OG 09-12-2011 09:37 PM
I placed 7/8" ID Plumber's Insulation Foam, cut to about 10 inches and jammed it up there. Left a 6" gap as per OEM but my sound pad took up the gap :D
Checked it on my second engine drop and it was in place, nice and tight.
$5.99 at ACE. It will fail Concours, oh well
88911coupe 01-02-2024 06:29 AM
I'm about to replace the sound pad AND the "blocks". It seems like the blocks, along with the bottom of the sound pad, are designed to seal the gap at the front of the engine bay. I'm assuming Porsche has some reason for this but not sure what it is. Maybe it has some effect on engine cooling by not pulling hot air from around the engine and exhaust into the engine bay?
Mark Salvetti 01-02-2024 10:28 AM
Yes, I think it is to keep hot air beneath the engine from getting into the engine bay. See this old thread (even older than this one): http://forums.pelicanparts.com/porsche-911-technical-forum/179798-hot-engine-bay.html
Mark
nospiners 01-02-2024 02:27 PM
I used HVAC insulation foam on the same spot while i was refurbishing the heat valves. i cant tell the
difference from before , but if the factory did it , they had to have a reason
