Driver side door sits proud of fender
Or maybe the fender is in too far - newbie here. I did try moving the hinge assembly all the way flush with the door post bit the door is still a bit too far out.
Any ideas for me? Thanks. |
abit off center
There is adjustment at the fender rear flange but you may have to remove the door to get at the bolts I don't remember when I did mine.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Agree with cgarr, you can try loosening the bolts at the rear fender flange and pull the fender out a little. You can get at them from inside the wheel well.
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Ah - so it is the fender that needs to be adjusted then.
Thanks guys. |
