-   -   Advice needed: SC electrical problems (http://forums.pelicanparts.com/porsche-911-technical-forum/629440-advice-needed-sc-electrical-problems.html)
Busta Rib 09-12-2011 01:55 PM
Just recently, the following components have been cutting in and out intermittently in my 1980 SC. They will occasionally all go out and come back at the same time:
stereo
cigarette lighter
fog lights
rear defroster
sunroof
speedo
I checked the fuses, all OK. I checked the ground for the stereo and it is solid, as well as the hot wire going into the stereo, which comes in directly from the battery, which is perplexing to me. Are all of these components on one circuit typically? Or am I dealing with an aftermarket wiring job from a previous owner? I am not a keen electrical person, purely a novice. I have a friend that is more knowledgeable that will help me troubleshoot, but I was just curious if there are some tips/insight anyone can share of this possibly being a common problem/solution with these particular items. Thanks in advance.
Jim
ErVikingo 09-12-2011 02:05 PM
Check the ground strap on the transmission.
gshase 09-12-2011 02:19 PM
Just because the fuses are not blown, they may be the issue. Take out each fuse and scotch brite each fuse and fuse holder, One at a time and give them a spin after you re install them to make sure they are seated. Those fuses will have a little corrosion on some of them.
86 911 Targa 09-12-2011 03:34 PM
stereo
cigarette lighter
fog lights
rear defroster
sunroof
speedo
Jim
Jim,
Do you have voltage on both sides of the fuses?
Busta Rib 09-12-2011 03:42 PM
Originally Posted by 86 911 Targa (Post 6250636)
Jim,
I'll check the voltage and the ground strap tomorrow and get back to you guys. Thanks.
