-   -   Removing Center A/C Vent (http://forums.pelicanparts.com/porsche-911-technical-forum/62972-removing-center-c-vent.html)
911nut 03-17-2002 10:17 AM
Since my warped dash is at it's worst right over the center A/C vent I have an idea to affect a tempory repair until which such time as I repaint my car and replace the dash and windshield. However, I don't have a clue as to how to remove the center A/C vent. Tried a topic search but I don't get the text with the posts.
Can someone tell me how to pop that sucker out? Thnaks in advance.
911nut 03-18-2002 06:55 AM
There's got to be someone out there who knows how to do this.....
goat43 03-18-2002 07:17 AM
The vent has four tabs, 2 on top and 2 on bottom, that grip the dash. Probably the safest way to get it out is to come at it from the trunk side, which you would do by removing the fresh-air plenum & connecting tube (a somewhat lengthy process), then reaching in with a big screwdriver and gently prying the top down until the tabs clear the lip of the dash-hole and it can be pushed out. You could try just gently prying it out from the interior side, but might be tricky not breaking it. Good luck.
cary 03-18-2002 07:21 AM
Carefully remove the fins/veins.
Using a flat screwdriver wedge/pry between the outside of the fin and the vent. It is kept in there with a short nipple that is molded into the fin. Keep track of the spring washer ..................
Then you'll be able to see the snaps that hold the vent in. 2 on top, 2 on the bottom. Use a small screwdriver to pry them up. Wiggle the vent out enough to keep the snap keeper out of its seat. Do this 4 times, then pull it out.
Now you have room for your hands to work on the dash .............
Good Luck:) :) :) :)
911nut 03-18-2002 08:11 AM
Thanks!
