Gauge and Switch bulbs
Good day !
In my 1988 3.2 911 is there a bulb in the headlight switch and how does one replace it ?
The books tell me the speedometer has 2 bulbs...how do I remove them to replace ?
Cheers !
Chris
Old 09-30-2011, 11:18 AM
JoeyD911's Avatar
Not real sure about the headlight switch, but the guage bulbs replace easily after you remove the speedo itself. They just plug in and out of the back. replacements are available from our host.
Joe D
L.I. NY
82 911 SC 3.0
Swartzmetalic
Old 09-30-2011, 11:36 AM
schumicat's Avatar
I don't think there's a bulb in the headlight switch. there isn't on SCs and I think Carrera uses the same part. the gauge bulbs are accessed by removing the gauge (pull out with fingers), the bulbs are powered by black wire w/ blue stipe, you have to pry them out of the gauge housing with a small blade to see the bulb.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 09-30-2011, 04:24 PM
