3rd brake light question
I have a 3rd brake light bracket mounted to rear window on 82 911sc euro. It must have been added when brought into states. I dont have the light. I ordered one from pelican and it is almost identical but the new bracket uses two set screws to mount light to bracket and mine must have just clipped in. I dont mind putting in the new light but I dont know how to remove old bracket without hurting the defroster. Both the new and the old brackets are oem and they mount with a double sided adhesive tape (that white one about 1/8" thick that has that thin foam in between) I was thinking of heating it with a hairdryer. seems like a dumb question, but would appreciate some feedback
Lou
Old 03-17-2002, 04:25 PM
rstoll's Avatar
That's the way I would do it. Plenty of heat with hair dryer, or a little heat from heat gun and a gentle putty knife. Slow and easy.
Robert Stoll
83 911 SC
83 944
Old 03-17-2002, 04:34 PM
thanks robert, I have heat gun I will use that. can I use a solvent to clean up glue residue. any ideas on what solvent to use?
Old 03-17-2002, 04:41 PM
rstoll's Avatar
WD-40 will clean up the residue, follow with windex. "Goo Gone" is good too. Some kind of citric extract. Careful with the heat gun.
Robert Stoll
83 911 SC
83 944
Old 03-17-2002, 04:44 PM
