Mitch Leland's Avatar
19MM wheel lug socket...
My 19MM wheel lug "soft" socket has cracked up... The plastic insert has cracked right at the end of the socket. Pelican doesn't sell just a "plastic insert" replacement. I think one problem with the plastic insert is that there's too much unsupported plastic protruding beyond the metal socket. Does anyone have a fix or know where you could buy the plastic insert?
Glenn at Pelican says they don't last more than a couple of years, and no I've never used the socket with an impact wrench...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 09-17-2011, 07:36 AM
Danny_Ocean's Avatar
Aluminum insert, instead of plastic:
TOOL Page (¯`·.¸(¯`·.¸ ZDMAK SPECIAL TOOL STORE ¸.·´¯)¸.·´¯)
Old 09-17-2011, 08:09 AM
Thanks Danny... you've gotta love this board!
Mitch Leland
Old 09-17-2011, 08:26 AM
Recreational User
porschenut's Avatar
I don't think an aluminum socket is going to protect the finish on your lug nuts as well as the plastic will, however. If it makes you feel any better, my plastic one lasted about a month.
Old 09-17-2011, 12:01 PM
Dave,
I think the aluminum will be fine, I have BBS 3 piece wheels so the lug nuts are covered anyway... I ordered one of the ZDMAK sockets that Danny recommended, I'll keep you posted on how well it works.
Mitch Leland
Old 09-17-2011, 12:29 PM
WPOZZZ's Avatar
Our host sell this one. I bought it, but have never used it as I keep forgetting I have one. Pelican Parts - Product Information: PEL-TOL-LUG19MM.
Old 09-17-2011, 03:36 PM
FWIW,..I use a piece of plastic wrap inside the socket to protect the anodized finish on the alloy lugnuts.
No impact guns, naturally.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-17-2011, 05:06 PM
Banned
This tool is a compete POS - the pin that holds the inner aluminum sleve in place quickly breaks away from the outer body - mine lasted about two uses, and since, I have read many reviews describing the same failure . . . hard to believe that Pelican still sells this!
Old 09-17-2011, 06:30 PM
I looked for "lug nut sockets" on the Pelican web site and didn't find this socket... Live and learn!
Danny have you had good success with your aluminum lined socket?
Mitch Leland
Old 09-17-2011, 07:13 PM
Immature Member
dentist90's Avatar
Mine did that too after about 2 years/ dozen uses. The socket wall is soft so I drilled right thru it (and the Aluminum liner) and pushed a roll pin in so it is secured on both sides. Seems much better now, but it is a weak link.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 09-17-2011, 10:49 PM
So far, so good. I don't use it a lot, though...
Old 09-18-2011, 11:39 AM
