Help- Fried Speedo Wire?
I pulled a boner.
While my speedo was out getting repaired at N. Hollywood I decided to pull the car out and wash it. When I went to pull it back in it had grown dark and I instinctively switched on the headlights. In almost an instant the 3 bare bulbs that were dangling through the empty hole in the dash winked-out.
All other gauges light-up, it appears though that the speedo is no longer getting power. I have not yet tried to hook it up since I figured that was a pointless exercise if the bulbs wont light-up.
I inspected the few visible inches of wiring before they disappear into the sheathing and no signs of trauma.
What/where should I check next? What do you reckon I did?
Cnutzzz
Old 09-08-2011, 03:33 PM
schumicat's Avatar
if the speedometer isn't there the bulbs aren't grounded. without a ground they won't light up.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 09-08-2011, 03:42 PM
E Sully's Avatar
The speedometer power is from a different source than the illumination bulbs. They both need a ground to work. The bulbs should light up when the speedometer is connected to ground.
Ed
1973.5 T
Old 09-08-2011, 04:37 PM
Yep- you guys were right!
I plugged it all back in and it's working like a champ.
Thanks!
Old 09-19-2011, 07:30 AM
