911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest blind rivet
Hi there,
The 911 coupe is notorious for door draft and wind noise. My car has a late style plastic door frame plug to prevent wind noise. It is installed with a blind rivet. The plastic plug is broken and I want to install a new one.
How can I remove the blind rivet?
I know I can drill them out, but I don't want the metal particles fall in the door (glass) frame, where I can't remove them.
Is there another way?
Thanks,
- Kees.
Old 03-18-2002, 09:51 AM
critter's Avatar
I don't know exactly what piece you are talking about but most of the swarf coming off the drill bit can be picked up by using a vaccumm as you are drilling.As far as the rivet body that is inside the hole you will probably have to open up the door to get it out.
Grant 75 911s targa
1991 Dodge Cummins turbo diesel 3/4 ton 4x4 ( stump puller)
Old 03-18-2002, 10:49 AM
