alt77's Avatar
Can end (banjo) fitting be purchased separetely?
The high pressure fuel line I bought (part # 911-356-066-07 OEM) is too large of a banjo to fit my 1977 fuel pump. Pelican told me it's the correct part number ^#%* .
The catalog states the "07" is for 77 to 89 and the number "08" part is for 83 to 89's.
Is the "08" part the smaller of the banjo's available ?
Any suggestions are appreciated.
Ric
Old 10-10-2011, 03:52 PM
alt77's Avatar
Clarification:
Can the fitting that threads into the fuel pump be bought separately ? I am thinking of replacing it with a larger diameter fitting to accommodate the larger part "07" banjo.
Old 10-10-2011, 03:56 PM
porwolf's Avatar
I think it can. I looked into that when I played around with replacing my 79 SC fuel pump with internal check valve to one with an external check valve. My fuel line has a 10MM banjo fitting for the internal check valve. But the external one requires a 12MM banjo fitting. I ended up with staying with the internal check valve fuel pump.
But here are some sources I found for banjo fittings:
034 MOTORSPORT
Banjo 12mm -4AN Male : atpturbo.com
Banjo - Fuel Line Adapter Fittings - SummitRacing.com
banjo fittings - Hydraulic Supply Co.
Earl's Performance Single Banjo Hose Ends - SummitRacing.com
And then there is always Google:
Google
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 10-10-2011, 08:02 PM
alt77's Avatar
034 MOTORSPORT
Google
Thank you porwolf, for your time and reply. Your information will be very useful.
You provided some excellent options for the change over, but I decided to have the old rubber hose section of the line replaced with new hose at Hose-man. This way, there will be no question regarding the size difference of the banjo and it keeps me inline with the original set up.
Old 10-10-2011, 09:45 PM
