fuel tank project
I have decided to take the fuel tank out of my 72 911S and clean it and paint it and replace the sender. This project does not seem to be in Wayne's book.Looking into the tank it seems to have a few rust spots but not much. Does anyone know what the process is... I heard al ittle about POR15 What is the correct paint for the early steel tanks. What kind of seal replacement? Thanks for the help in advance
Maxle601 |
Having just completed this project, I can offer a little insight.
My tank had more rust than you described, so I did the "boil out" first. If your tank just has minor rust spots, I wouldn't worry-almost every steel tank has them. To prevent further rust, try to avoid gasoline containing alcohol (such as ethanol). It attracts water from the atmosphere. You can use quality foam tape (I used cap tape for a pickup) and 3M weatherstrip adhesive for the seal. Replacing the sender is forthright. New gasket may be needed. This is a sender after 18 years in a barn!
Mike B. '72 911E Coupe Early "S" #1065 |
I do this to my 911 72.
Remove the tank and clean in with gas to remove all the rust debris inside. Then I put 2 cycle oil into the tank to seal out the rust spots from the ambient for the time that I paint the tank. I dont use the foam seal. I just buy caulk and put it around the tank hole. Also buy a new fuel filter. Good luck.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
Guest
Posts: n/a
Here are pics from my late model Carrera tank that I restored into my 73 RS. Inside was in good shape so I left it alone. I POR-15 the edges and the bottom. Then I painted the bottom Rustolium black and the top grey. Its an oil based paint and adheres to the rubber coating well. Just clean the tank with Castrol purple cleaner first and degrease it first. Make sure you wear gloves because it can dry out your hands pretty well!
I also went to Home Depot and got some 3/8 foam weatherstriping tape to seal the bottom of the tank. It came out great.
Joseph, where did you get the grey paint?
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
Yeah. Where did you get the gray paint. Mine's flaking off.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
Will program for food
Did you use Wurths SKS?
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
The original coating is flakingoff. I haven't painted it yet.
Looks to be Wurth Stonegard in Grey.
Warren & Ron, may you rest in Peace. |
looks great!!!
SKS Stongard
Bumping this to ask if anyone would know if 1 bottle of SKS Stonegard is sufficient to cover the entire tank? Thanks in advance for any responses.
bump
is 1 bottle of Stonegard enough to do an entire fuel tank?
